carowockner
The truck is for sale for 25,000 or trade for a diesel 4 door Dodge (may be open to other trades).
157k miles on body and chassis.
Spring over axle shackle reversal kit from 4-Plus Products (should go with heavy springs in the future)
Axles cut and turned for angle
4.56 gears
Professionally swapped 12 valve Cummins out of a 94 Dodge with 158k miles
Brand new P-pump (p7100) from Farrel Diesel set to 215 HP
New Dynamite Diesel 80 HP injectors
Torfab motor mounts
Professionally built custom radiator and intercooler
NV4500, 5-Speed manual
Dual battery setup in the rear, Optima Red Top batteries
4" straight pipe exhaust
Both bumpers are from 4-Plus products, rear is dual swing-out with tire carrier, propane mount, ladder, and jerry can holder
Tuffy center console
New Australian door cards
35 x 12.5 BFG All Terrains with black steelies, matching spare
Custom roof rack with front runner mounts
Odin Designs Type E RTT
Odin Designs 270 Degree Awning
Included fiber glass fender flares (not mounted, cannot buy in the US)
Auxiliary fuel pump
New South Bend Heavy Duty Clutch
ARP Head studs
This vehicle has over 20k in receipts. Has minor rust on wheel wells. All glass intact with tint. Thoughts for the future - speakers, interior door handles, new shifter boots or covers due to moving transmission position for swap. More photos can be seen @bruiser.the.cruiser in IG.
The trailer is 1951 Royal Spartanette. We call it the Space Twinkie. The interior has been completely gutted and insulated with rigid foam board. It comes equipped with a wood stove, bath tub, shower, on demand hot water heater, and original stove/oven and fridge which work perfectly. The hubs were repacked and it was towed 200 miles without issue. The title was lost by a previous owner and it comes with lots of paper work that could be used to obtain a title. Dimensions - 8 x 32 feet, 35 including the tongue. The truck will tow this trailer no problem. $40,000 for both trailer and truck.
4.56 gears
Torfab motor mounts
Auxiliary fuel pump
ARP Head studs
