Custom Modded ARB bumper, Part 1
02TahoeMD
ARB Winch Bumper Conversion
Over the past year I have been looking for a winch bumper for my Tahoe. I wanted one with lines that went well with the vehicle ( at least, to my eye ) and didn’t weigh 300 + pounds. I liked the overall design of ARB's Chevy winch bumper but, it did not have bumper pads, the built in fog lights, and just looked too big for a Tahoe. After some research, and having seen a Toyota FJ bumper modded to fit a Trailblazer (thanks for the idea there AlekG!) I figured I would try my own conversion. After consulting with Lee "Hoser" who graciously provided me measurements and photos from his ARB install on his Lexus, I knew it was a reasonable possibility. So, I got the ARB winch bumper made for the 100 series Land Cruiser and set to work. As with my Safari Snorkel conversion, I am sharing this project here mostly to share techniques in case someone wants to try something similar. Here is what you will need if you want to do this project for yourself.
FIRST AND FOREMOST: ARB indicates Thall Shalt NOT modify THY bumper in any way, shape, or form, or the warranty is void, etc etc etc. And, I guess I should say that this is a proceed at-your-own-risk project.
ARB Winch Bumper part # 34013090
ARB Chevy Fit Kit part # 3562010
4.5" cutoff wheel/grinder
Sawzall
Assorted hand tools
welding equipment OR a shop you can go to for welding
pipe bending equipment (not mandatory) or a shop equipped with it
For starters, I took off the factory bumper. This is done by removing the grille shell and undoing the center 4 bolts that hold on the bumper to the frame, then removing the "wing" arms that are attached to the outer frame mounts, 2 bolts each wing. Before replacing the grille shell, snip off the 2 locating tabs that are on the lower portion of the grille, this will make removing it later much easier.
Next, discard the frame mounts provided for the LC bumper. Use the mounts from the Chevy kit and bolt them up to the appropriate holes in the frame. There are instructions included from ARB for the full install of their bumper for the Chevy product, just follow how to bolt up the mounts. Don’t tighten anything down for now, just snug.
Set the LC bumper on top of the bumper mounts, this will give you an idea of how much you will need to cut off of the mounts to make it fit. I took off about 3" of the mounts, you can see the photo with the finished results of all the steel I cut off highlighted in red.
If you are using a winch, you will need to make some room for it on the mounts as well. Do this by cutting away the inner "fold" portion of the mount. Again, check the photos to see where I cut away. If you are not installing a winch, skip this step.
Next you will need to cut away about 1/4" off the inside portion of the bumper itself, the portion that sits on top of the bumper mounts. You can get the exact amount by measuring how much the bumper needs to drop down by test fitting the bumper after cutting the mounts. I got very, VERY lucky in that I was able to do all my cuts right the first time. Again, see photo with highlights….
Test fit the bumper to make sure you don’t need to trim away any more steel for the fit. You will need to drill one new hole on the bumper for the mounting bolts (grade 8) you will use to bolt to the Chevy mounts. You can find this hole by marking the spot during test fitting. These holes are visible through the fog light housing openings.
After drilling the holes, bolt up the bumper and snug down.
Now, you will need to cut off about 2" off the wings of the bumper, as you will see that they extend into the front wheel well. Mark two cut lines on each bumper, using the wheel well as a reference for the contour. One cut about 1/4 inch back from the edge of the "cap" portion, the other cut back on the line that will clear the wheel well.
Here is where the welder first comes handy - and you can do this cutting and take the bumper up to a shop and have the work done if you do not have access to a welder. Again, I got very very lucky and had a friend to help with this stuff. Weld the "cap" back on to the bumper to give it a finished look.
Also, take some scrap steel and weld in a spacer to fill the gap. (see photos) Clean up the welds in with a grinder, smooth up the finish with some Bondo, sandpaper, and paint.
Also, paint all the mounts and places where any grinding took place. I put down several coats of black Rustoleum followed by 3 coats of spray undercoating on the mounts. Then mount the winch (I used a MileMarker 9000E) according to directions and bolt up the entire assembly and snug down all the bolts. Install the fog light assemblies according to the directions.
Now, you are basically done! Which is how things will look here, with a side by side comparison with the bumper made for the Chevy product.
I did find that the bars across the headlights cut down the light output, perhaps by 30%. There was no shadow to be seen, just the lights seemed dim. After consulting the pics from ARB's site, it seems that the switched to using a tube that was about 2X thicker than the one in the initial production line, thus blocking the light a lot more than I think it would have originally. Of course, if you have some HIDs or really bright lights in the fog housings, this could be a moot issue. But I wanted to do something different, I decided to modify the headlight hoops. This ended up being fairly easy - I went to a shop, where they cut off the hoops at the junctures of the grille guard and lower light guard. They bent some tube steel to the design I imagined and welded them in place. Then I just went home and painted the hoops. The loss of light was completely fixed and it also made removal of the headlight assemblies MUCH easier.
I also got some shackle mounts off of eBay and had them welded on the bumper as well, no winch bumper seems complete to me without shackles!
Also, other details - I painted the roller fairlead ( you HAVE to use a roller fairlead on this bumper, can't get away with the hawse type ) black to match the rest of the finish. I also replaced the entire spool of cable with 90 feet of 3/8" synthetic winch line from Viking Off Road. This stuff was so much lighter than the spool of steel cable it was nothing short of amazing. Not to mention, it is so, SO much easier to handle.
02TahoeMD
Bumper Mod, Part 2
I also wanted to mount the winch control box in a different place than what was in the instructions for ARB, which is to put the box in the center of the bumper between the fog light mounts. So, I took apart the control box and installed the long battery leads that came in the ARB kit on the solenoid (power out) side of the box, and put the short leads on the battery ( power in ) side of the box. I also decided to mount a wireless remote so I did the wiring for it at this time. I reassembled the control box and mounted it to the fan shroud housing, and routed the cables to the winch and battery leads.
I then ran the wires for the wireless remote through the firewall and mounted the receiver to the center console.
Wireless remote is no bigger than a keyless entry fob and works up to 50 feet away.
Lastly, I wanted to have a true skid plate on the truck, as the one for the LT is made of …….plastic! Anyway, I made a template of cardboard and had my metal shop make one of 3/16 diamond plate steel. I treated the back of it with spray undercoat and mounted it up - a photo here shows it before its final coat of black.
This project really was not too hard, it went a LOT easier than I had prepared for, and I am pretty happy with the results. The approach angles are vastly better than the factory bumper, not to mention I have a vastly stronger assembly up front to intercept errant critters as well as having the winch now.
Zatara
Your build looks great however, maybe it's just the angles of the pictures but it looks like the upper bar obscures the headlight beams.
The pics I have seen of the ARB for the Chevy has that upper bar up higher and the headlights look more visible.
Am I just seeing it at an odd angle ?
02TahoeMD
Thanks for the compliments. Carlyle, I would have to say you are a good fabricator, you have modded your Alaska Camper with all kinds of goodies.
The headlights were blocked by the old headlight hoops, with the new ones there is no loss of light at all. Looking straight on eye level with the headlights, the new bar is actually about 1" highter than the top of the headlight, so I guess it is just the angle of the photographs.
The good thing about the LC bumper is that I now have a lower center portion of the brush guard as well as a narrower bumper ( about 4" more ) which makes working on the engine bay a good bit easier than the taller and wider one made by ARB for the Chevy.
4Rescue
Nice work mate. Looks professionaly done, and I dare say it even looks cooler with the moded headlight hoops eh. I am interested though as there's a "chevy fit kit" but you still had to mod the bumper? Either way, nice work.
Cheers
Dave
02TahoeMD
Thanks 4Rescue.....to answer your question: I used the "Chevy Fit Kit" since it has the direct bolt on brackets made by ARB for their Chevy bumper. They make one Chevy bumper but several different sets of brackets for it since it can fit 1500 and 2500 series trucks, which have different frame dimensions, and they sell these "fit kits" seperately. I figured it would be a heck of a lot faster to just use the Chevy brackets than to try and modify the Land Cruiser brackets that came with the kit. I was trying to do the mod as cheaply and quickly as possible, and it seemed that the Chevy brackets would provide that route.
And the rest of the fit mods came because of the slight dimensional differences in the Tahoe vs. Land Cruiser. Again, I could have used the Chevy ARB bumper but it just looked too big to my eye for the short Tahoe. Not to mention, it didn't have the fog light housings and bumper guards.....and besides, I always want to do something ...different. Can't help it. :coffeedrink:
4Rescue
AHHHHH I see... In that case, extra well done eh, and again, whatever the process was, it looks damn good and professionaly done.
Cheers
Dave
Dr Skeet
amazing man
you are truely skilled! i will be in touch on creating my own unique arb bumper like this. haha i think im in love with you and your truck!!!
silvrzuki77
explorer
Looks good! I found a tundra sahara bumper in the junkyard for $50. But its about 4"to narrow for my superduty! Im doin the same as you but they dont make a fit kit for my truck.
General Automag
What did you do for the rear bumper? The front ARB bumper looks great on your truck. Please post pictures of the rear bumper if you have any. Thanks:)
WonaWarrior
