I probably got the wrong thing, but here goes.
My truck shell camper build. I need to provide power to...
#1. Alpicool APLT60 60 liter / 63 quart LG compressor fridge. 45w rated, this obviously cycles on and off so not a constant draw, but it draws on and off 24x7.
#2. Z2 Travel CPAP. Only runs when I am trying to sleep, so 8hr / overnight, no solar coming in. 35w on ramp up, 20w running.
#3. Asus Rog Strix G17 laptop. 100w USB C charging, or 240w 110v through the inverter.
#4. Samsung Galaxy Note 9 phone / camera / wifi hotspot etc... I have a separate solar charger for this though.
My charging circuit looks like this.
#1. Atem Power 20 amp DC to DC charger / mppt solar controller. Does NOT have a specific profile for LifePO4, but does for Lithium Ion. Both Atem Power on their website, and several sellers say it can be used for LifePO4, allegedly by using the AGM profile. Need to verify this.
#2. Obviously, or a least I hope it is obvious, High output alternator, TBD at the moment for my 2004 F150 5.4L 3V, yes new engine been bulletproofed as much as these can.
#3. Dokio 300w portable solar panel kit. This is to be deployed when in camp. The charge controller that came with this DOES support LifePO4.
So I have a dilema. I would like to go with Lifepo4, but don't think my DC to DC charger will do the job, I can charge with solar no problem and have more than enough power with a 200 amp hour battery, but that also poses a physical storage problem. I was originally planning on a Group 31 AGM battery in a Ford E series cab and chassis mount under the cab of my truck. I am not super skilled with metal fabrication so making my own larger under body mount is not exactly an option... What can I do for battery / battery bank?
And what can I do for a charger that will handle from the alternator charging AND solar AND Lifepo4?
