Many projects in the works for the Defender this month! Over the next few weeks there will be many updates of the defender becoming equipped to hit the trail.
I ordered a t-max dual battery system, which is in need of installing. Before being able to install it I needed a dual battery tray. The only one I could find is the Flatdog dual battery tray. Its a great looking product, but it only works will optimas. The height of the optimas is shorter than a run of the mill battery, and if modded to fit a normal battery, it will require the cover piece over the battery compartment to not be used. Since speeding $600 on battery's is not not an option at the moment, and not using the cover would drive me crazy, I decided I had to build my own battery tray. The tray I built allows for a normal battery to be used, but the height can also be adjusted for the lower optima. To ensure the cover would fit with the higher battery I had to make the rear point lower than the other two to compensate for the downward angle of the seat box.
