Welp I took about 4 months hunting for my jeep. I grabbed a 2006 low miles lj with an auto. Ended up with an auto after my last tj. After a few hitches in the Marines my left knee doesn't hold up to working a clutch all day on the trail.
Well the LJ's are hard to find especially with an auto. This one was red , so we grabbed it only thing it was missing was cruise control. I have just finished my research into cruise to find out mine is missing the factory plugs and wiring. It seems some jeeps come pre wired with the correct clock spring even if they did not come with cruise.
After searching the engine compartment for my factory plug I had to admit I was one of the unlucky ones. W/O the factory wires it becomes a pita to do the swap in. Goes from plug and play to rip and splice. I may go hunting for a wrecked cruise jeep and just take the whole durn harness and swap it in. Splicing wires is a pain for me being both types of color blind, so it is a real chore.
It seems it do this correctly you must have the clock spring with the cruise pig tails the correct year buttons for the steering wheel( diff yrs have diff resistances) the actuator and cable(speed control unit) vacuum line and wiring harness.
If you have the pig tail under the hood you should have the right clock spring and grab the speed control buttons , plug em in and away ya go. without the factory harness you have to splice the wires all the way to the ecu along with the speed sensor to the brake pedal.
Just jeeps has a full kit for 298 for the hard parts and another 300 for the wiring but it is factory when done.
If anyone has any other feed back on the possibility of retro in cruise for a 2006 lj then let me know please.
Being 6'2" in an Lj is a blessing to have cruise for the long road parts of a trip.
