Diff Fluid FG649
seangrips
Pretty sure the fg637 has the same running gear.
Oil Type: Castrol J Max 15W40
Ash 1.5% or higher
Class. CD CE CF4
Capacity. 8L + 1L filter
Gearbox
MO35S5
Transmission. 3.4L
API CD
SAE 30 or 40
Transfer. 3.0L
API GL-4
SAE 90
Axle Front. 3.0L
API GL-5
SAE 90
Axle Rear. Limited Slip Diff 2.7L
API GL-5LS
Power Steering. 1.8L
Auto Transmission Fluid
DEXRON II type
Coolant. 13L
Notes:
Diesel Filter P550049
Fleetguard FF5088
Rear Diff LSX90
Front Diff EPX80W90
Gear Box Castrol TFC450 SAE50
Oil filter (FleetGuard LF3830)
RYCO Z372
Air Filter AF409KM
Or Donaldson P182054pointhk
yabanja
I follow all factory recommendations except on the rear diff. Because it is a clutch style differential it is very sensitive. If you put synthetic fluid in there the LSD will stop working. I use conventional API GL-5 and I add two bottles of Ford LSD Friction Modifier. If you don't do this you will feel binding when you make sharp turns on hard surfaces and your front tires will get a feathering wear pattern on the outer edges.
Allan
Howard70
We used the correct lsd fluid from Mitsubishi. And it works well. Good to know that lsd additive will work as well
Hello Cameron:
I use an LSD fluid from Mitsubishi also and favor it over others combined with LSD additives that I've tried. The Mitsubishi fluid I use is "Mitsubishi DiaQueen GL5 LSD Gear Oil" which I get from Modern Automotive Performance, Is that the same as you use? I can't find the Fuso specified fluid and while I assumed they are the same I'm not sure.
Howard
Smudge12
