Hey y’all!
I ripped a high top off an old van at the junkyard, got my roof cut, and am now deciding how to install. There is little to no info online and I would love some opinions. Its a 99 extended 4x4 E350 and the top came off the same -4th gen extended ford van. The fiberglass top doesn't have a lip which makes it a bit harder to install. So far my plan is to clean the area, drill in long self drilling metal screws, and then silicone the in and outside. Should I utilize weatherstripping at all? Should I utilize wood and install in some way between the fiberglass and metal for added stability? Do you think just the screws and silicone will be enough to safely secure it? Ideally I would use bolts and nuts but I cannot access the underside to apply a nut. When I pulled it off of the van at the junkyard, it appeared to be held on with just screws and silicone so Im assuming it will work but want to make sure it will hold and that water will not leak in/sit in the gutters. I’m not high maintenance and it by no means needs to be professional, just trying to make it secure and avoid leaks/pooling. Any info or advice is greatly appreciated!
Also as you can see in the photo, there’s an opening above the doors. The van it came off of was an old handicap van with the large bus-style doors. I plan to build and install a custom window there.
