DNJ timing belt kit
KarmannMarco
Have any of you guys had any experience with DNJ timing belt kits? Its about 1/2 price of the Gates kit. Is the Gates kit higher quality? I'm getting ready to do the timing belt and water pump on my 97
greg409
Given how seldom we replace timing belts & associated parts, I wouldn't go cheap (gates should be decent for the belt) I like goodyear gatorback stuff myself
On another car, I went cheap, then did it again (with 4 valves) 14,000 mi later - never again
luck,greg
shov3lbum
Agreed, get good parts; especially with our interference engines. I went with an OEM belt and then gathered other various parts through rock auto, I used an Aisin water pump, they are the manufacturer that makes the OEM mitsu parts if I'm correct.
I also went with OEM/Mitsu direct for the hydraulic auto tensioner as I've heard of aftermarket ones leaking. The best way I found to get good prices is to go a OEM wholesaler like mitsubishiparts . net and then have the dealership match the price.
Good luck, J
MonteroLTD
My experience with Dayco has been good. I'd recommend DNJ, Gates, Dayco to anyone. You'll be fine. What's most important is the job being done right (The first time).
WonaWarrior
