It's a tight fit but it works with one small mod. With the grab included handles attached, there is not enough room for the CF80. I installed soft grab handles with 1/4" fender washers and it barely fits. There is certain pressure against the rear seat.
CF80 Pros:
- Large capacity
- Low deck - lots of room to store bags on top
- Perfect fit for the 4-door JK
Cons:
- must modify the grab handles
Thoughts and observations:
- If you're using an action packer with it, mount the lid to open from the passenger's side. Getting to the latches with the action packer there is a hassle. To open the lid, you must slide the fridge back a bit, so you can only open it when the tailgate is open.
- Make sure there's sufficient ventilation for the fans. They must face forward and there is a gap between the rear seat and the fridge. I keep the action packer back and there's sufficient space to allow for air flow.
- The power cord is barely long enough to reach the front cig lighter outlet. I have purchased an extension for it.
CF80 Pros:
- Large capacity
Cons:
