Double Sleeping Bags
Lynn
I looked at the Slumberjacks at a local shop today and will be showing them to the wife later.
I take it by your statement that they come in LH and RH zips? The shop only had RH zips.
How would you rate their warth accuracy? They had 0*,-20* and -30* bags, but nothing in the 20-30* range.
No, on the rectangular bags you just unzip one all the way, lay it out flat, unzip the second, lay it upside down on top, then zip the two together.
On mummy bags you have to have LH and RH bags because you lay them side-by-side.
We've used ours a few times, but always well below the rating, so I can't really rate them on rating accuracy.
Fergie
Well, the local outfitter had the Slumberjacks on sale, so we bought 2 of the -20* bags this evening.
I'll get a couple dry bags to store them in for trips, and call it good.
Christophe Noel
We sell a ton of the King Soloman bags. Never heard a single complaint, but we have heard lots of rave reviews. That would be my vote.
skysix
My 1st choice is a two part inner/outer 5 season semi mummy design from Blacks in the UK circa late 50's, "Icelandic Double" (with ratings to -40 ambient by itself). It can be zipped together along the sides to make a 2-3 season doublewide bag. Unfortunately high price and hard to find but very lightweight (800 loft eiderdown).
2nd choice is Norweigan, the Ajungilak (meaning "sleep well" in the Inuit language) Gronland, which is a 4 season down inner/outer combination but the zipper ends up in the middle (unlike the Blacks). On the other hand I added a neck tube/baffle around the neck (duh) area of both - also down filled - which cuts down the drafts when not using the mummy hoods done up tight. Allows seperate movement (can velcro together as one large baffle or each with your own neck baffle).
3rd choice is the Norseman NorthStar 8 sleeping bag rated to -40. This is a heavy duty industrial grade 2 bag in one system whereby you can use the shell/outer bag only which is rated to -10 or keep them zipped together for an Artic rating of -40. The bag is filled with over 8 lbs of Dupont Hollifill. Get a spare second shell and you can use the inner bag to zero. Use them as a quilt with 3 choices of insulation or (using the second shell and inner bag on the bottom) you get a -10 double bag. Gets drafty if you move apart just like a quilt that is tight on the bed and a little undersized. Can usually deal with this however with a little effort.... Volume packed is about the same as a FULL navy duffle bag...
Don't skimp on an adequate foam pad and distance above the ground/floor either! Try a 10cm thick air mattress (NOT inflated by mouth or it'll fill with moisture and freeze as well) with a 15mm Evazote pad on top.
Greggk
ZombieSoldier
Greggk
ZombieSoldier
really? i mention camping and my wife runs into the garage and starts getting her stuff ready...
Errant
We use the Big Agnes King Solomon paired with their IAC pads. I'm 5'10" and he's 6'3". It's very comfy, much better than any other double bag setup I've used.
sctracker
With most mummy bags if you buy a regular and a long the zippers will be on opposite sides so you can zip them together. You wont be able to keep your feet hers but she might not mind!
Mamontof
ummm that doesnt look like a 2 person sleeping bag...
Do you ever unite two mummy bags in one fun one ?:elkgrin:
It look funny as have two legs :Wow1: departments , only any way woman some
hay chose all the time one...so one department will be empty in other 4 legs :Wow1::ylsmoke:
To why a Mormon or from Scandinavian.... you should newer bring 2 girlfriends
, for 6 legs way to tide in one department
Psyph
