Dual Battery Management
njtaco
IIRC, the field connections are to disable the alternator when switching between batteries. As you switch, the alt. is "shut off" so it is not damaged when the batteries are momentarily disconnected while the switch is making/breaking.
Desertdude
according to the diagram this appears to be the case.
• AFD: Cut the field wire from the alternator to the voltage regulator; connect one end to F1, and the other end to F2.
>>> So, you would need to have a wiring diagram to suss out on your specific vehicle what color and where the wire is to cut <<<<
9002e AFD PDF diagram
Beowulf
So as it has been almost two years since the last post, I wanted to bring this thread back and check in for management unit reviews, Solar panel upgrades, and batteries selections.
Beowulf
Just got the latest issue of OJ and it has all the reviews of Management Systems anyone could want.
flipstick
