K9 Roof Rack Shovel, Axe & Hi Lift Mounts
Equipt is proud to announce the launch of 3 new K9 Roof Rack Accessories
K9 Shovel Mount
The Eezi-Awn K9 Shovel Mount is an ingenious way to mount your recovery shovel to the side of the K9 Roof Rack System. It is designed to accommodate any size of style shovel by clamping to the handle shaft instead of the blade or handle end. The cover clamps down to reduce rattles, and there is a loop provided for attaching a lock. The mount has a flat back surface, and utilizes one of the K9 Accessory Adapters to attach to the side of the rack. Accessory Adapter is included with Mount. Price: $55
K9 Axe Mount
The Eezi-Awn K9 Axe Mount is designed very similar to the shovel mount, with the exception of the tool cradle. The cradle it deeper and a bit more narrow, to better control the traditional style axe handle. Price: $55
K9 Hi Lift Mount
The Eezi-Awn K9 Hi Lift Mount with cover lets you store your Hi Lift on the top or on the side of your K9 Roof Rack. It consists of two parts, a base bracket that has a positioning pin and bolt location, and a handle/ladder bracket to hold the top end of the lift. The bracket clamps down over the handle and ladder, and includes a positioning loops that keeps the ladder in place and provides a hole for a lock. The bolt in the base holds the hi lift base tightly in place reducing rattles. Hi Lift Mount includes a cover for the lift mechanism, to keep the elements away. Price: $86
Though each accessory is designed for use with the K9 Roof Rack System, they are easily universal. The back of each accessory is flat when the adapter is removed. It could be mounted to most any flat surface.
Cheers,
