snowblind
Hello all.
2 years ago I upgraded the cooling fan on my 2001 Suburban from the stock mechanical unit to a dual electric unit. I am using a Flex-a-lite variable temp controller for the power. Controller takes a blue turn on wire from the AC compressor.
Recently my AC compressor failed and I had a new unit installed by a GM dealer. At that time the GM tech told me that the electric fans were "icing up" the refrigerant. His reasoning was that the fans were on the entire time the compressor was running and that caused the "accumulator" to freeze up. It was his opinion that this freezing would cause obstructions in the AC system and the compressor would fail due to running at too high a pressure.
I replied "That sounds very strange to me. Refrigerant isn't supposed to freeze right? Do you think maybe there is some water/dirt/oil INSIDE the system that is causing the freezing" Dealership had no answer.
Fast forward 3 weeks and the new AC compressor starts making failure noises one morning. Compressor has a lifetime warranty but dealership says it's because of the electric fans. I call bull**** and reference some earlier problems with the rear AC that indicate there were particles in the system even though I paid for a flush.
End result, dealership flushes entire system, installs new AC compressor, new accumulator and new rear control valve at no cost to me. Everything is working great but the dealership still says the electric fans will kill the new compressor.
Has anybody heard anything like this? Wouldn't the electric fans be set to cycle on AC mode? Just cut out for 15 sec? What do you do when the fan is on for engine heat?
Thanks,
Matt
Thanks,
Matt
