jdholder
So, I have an Engel MR040 and one of their remote thermometers with "High, Low and Ambient" readouts.
A few times, when I get in my truck, after a night of camping with the refer set to cool to about 34 degrees, I will notice that while the refer compressor is running (I can hear it) the temperature telltale will indicate that the refer got up to 45 or so degrees (admittedly on hot nights).
The refer is wired into a second battery that is charged by the alternator (simple solenoid setup) - and the second battery is just a standard "Die Hard" to match my starting battery. The two batteries are separated with key off.
So, my question is - Bad refer? Bad battery? Bad thermometer?
I think I have it narrowed down to a low battery situation as I tested voltage before start-up on one of the mornings that I notices this happening and the battery had 11 volts.
I am only puzzled cause the battery is new, the refer has never given me issue and the alternator is putting out 14.7 volts when running (just had a new alternator installed).
The ONLY thing running off the second battery is the refer.
I don't have the space to install a big deep cycle battery.
Any recommendations?
Thanks!
Thanks!
