I also posted this over at IH8MUD. It is a rough draft of an idea I had. Text is a bit modified here. There are also a number of other ideas in that thread.
This is for a engine heated hot water, not direct shower water. Mixing the hot water with cool water would be needed for showering as the water temp in this tank design would eventually get close to the engine coolant temperature. The tank idea is modified from the boat hot water heaters like the Isotherm units. I haven't built this yet. I'm not yet to the stage in my vehicle build to be installing stuff like this. It is just a possible design at this point.
I designed it using standard off the shelf parts available here in the US. Only a very little fabrication is needed and that is only to support the ends of the copper tube against road vibrations and for the outer case.
Start with one 2.5, 3, or 5 gallon premix soda keg. Get one that has a pressure relief valve in the lid. Note the type of input and output connectors it has. The parts I show and link are for ball lock kegs. There are pin lock versions of the parts I show. When you pick up the tank and other parts you may wish to pick up some extra o-rings for the lid and quick connects on the keg.
OK, wrap a length of 1/2" copper tube tightly around the keg near the base. See picture below. Orientate the input and output tubes suitably for your installation. Use a tube bender for tight bends, or just use suitable angle fittings. How long should the tube be? I don't know. What spacing to use between wraps? I don't know. Personally I'd just get a 60 foot length and wrap it all and pack the wraps together.
On each end of the copper tube install a hose barb appropriate for your heater hose size. Use a brass barb rather than clamping to the copper tube because clamping to the tube will likely crush it plus it is a smooth tube with no grip. The fitting could either be soldered on or a flair fitting. It don't matter. Some support for the ends is a must. It would be good if they were affixed solidly so the tube does not flex from road vibrations. You will need to fabricate something to do this.
I'm thinking of using liquid nails to glue the tube in place, but I don't know on that. Suggestions? It is important to have a good thermal connection and that it holds up over time. I suppose you could solder the tube on.:sombrero:
I'd plumb the coolant source and return hoses in parallel with the heater core hoses. Just use a couple y fittings plumbed inline before the heater control valve. I'd also insulate the hoses if they have to run any distance.
For extracting hot water out. There are keg faucets that directly connect to the output port of the keg.
I'm not sure how the quick connect and keg faucet will respond to 180F water, but it is worth a try. It can always be replaced by regular pipe fittings. The keg faucet works for extracting the water because there is a small tube going from the bottom of the keg to the output port.
For pressurizing so the water will flow out. Use quick disconnects with hose barbs to connect your pressurizing system up to the tank.
Add to that a hose and bits for whatever pressurizing method you want. It could just be a metal valve stem cut off and clamped into the hose, or and elaborate regulator hooked up to the on board air system.
Around the whole tank I'd insulate it with expanding foam. It would be good to have an exterior case but that can be your choice. I'm thinking a stainless steel tube then filling expanding foam in between it and the keg. Depending on the strength of the expanding foam the keg could either be supported by it or need some extra support structure.
Refilling the keg is via it's lid. Open the lid up and pour in water from your jerry can or use a hose. Leave a couple inches expansion room at the top.
Heating happens while you drive. With enough insulation it should keep the hot water hot for many hours.
With all new parts it should be under $300 without the case. Using a used reconditioned keg will chop $60 to $70 off that. As an aside I will mention that an Isotherm water heater unit is only around $700 to $800 but would require a pressurized cold water system due to how they plumb the exit port.
It would be possible to use a temperature controller and heater valve to control the temperature in the tank, but I was looking for simplicity. The temperature control could be as simple as a bi-metallic switch glued to the side of the tank. I'd make sure the circuit is de-energized when the engine is off.
Alternate types of tanks could be used with this design. I've seen people use old fire extinguisher tanks for pressurized shower systems. They would work too.
I attached the images in case they vanish on the web.
