So I started the truck after timing belt replacement and the truck is ticking or knocking pretty bad. I I double and triple checked the timing marks and everything seemed to be lined up fine. It does sound like the valves might be making contact but I'm not sure. The noise is also noticeable when under the truck . I was thinking maybe the lifters since it was sitting for a couple weeks but I'm not sure . I just listened again and the noise can be heard out of the exaust downpipes . If the valves are making contact do you think its damaged permanently? Here is a link to a video I took.
http://youtu.be/_CrmTgILWZ8
Sound from underneath
http://youtu.be/gzWN5LcIIkM
