I had the same issue with that o-ring. Replaced t-belt and everything else on the motor a little over a year ago. A couple of months ago I started noticing I was losing coolant and couldnt figure out where. Then I saw the puddle in the V. As much as I dreaded taking the top off again it wasnt that big of a deal. I had already done valve cover gaskets, rear cam/cam sensor seal, plugs/wires, knock sensor about 5 months ago, so it was just a quick R and R to fix the leak. I removed the tube, put grey RTV on the o-ring and let it sit overnight. It has been leak free for 2 weeks now.
