Reapirs and Faults
Google
Repairs and faults
· Reinforcing the left driver's cabin holder at approximately 55,000 kilometers
· Replacement of the defective coolant expansion tank from thermoplastic
through a stainless steel container at approximately 55,000 kilometers
· Replacement, damaged by falling rocks, windshield
• The rear transmission shaft seal is leaking, because there is a slight
Oil loss of about 0.5 liters per 3000 kilometers. An exchange of the Simmerring
it is still necessary, but should be at a major maintenance work
integrated
· By a leak in the roof was wet the wood next
and cracked, the window is now close, the visual defect
unfortunately left behind (this defect had existed for a purchase)
· The seal of the tank return flow connection between the main and
Auxiliary fuel tank is leaking overcrowding at overpressure, respectively, and may, at
Inadvertently lead to loss of light diesel (also this lack
already existed for a purchase)
· Plastic cover on the forced-slider on the dashboard is missing
· The paint flaking off, especially on the cabin at many places on
Request, we can paint the car, although the
used look, especially in poor countries an advantage. Since construction
is made of aluminum, there is no risk of rust
· The vehicle partially shows clear signs of use, which
Functionality does not affect
Babelfish
Repairs and lack
· Reinforcement of the left operator's cab mounting plate with approx. 55,000 km
· Exchange of the defective cooling water header tank from thermoplastic by a Edelstahlbehälter with approx. 55,000 km
· Exchange that, by falling rocks damaged, windshield
· The rear transmission shaft seal is leaky, thus a lighter oil loss of approx. 0.5 litres per 3.000 km exists
. An exchange of the shaft seal is not necessary yet, should be integrated however with a larger maintenance work ·
by a leaky place at the rooflight the wood beside it damp and fragilly, the window is meanwhile close unfortunately remained, the optical lack (this lack already existed with the purchase)
· the poetry of the tank return connection between main and Auxiliary tank is leaky with positive pressure, and/or overstocking and can lead with inadvertence to easy Diesel loss (also this lack existed already with the purchase)
· Plastic cover of the circulating air sliding control at the instrument panel is missing
· the lacquer peels particularly at the apartment cab in many places, when desired can we the vehicle paint let, however the used optics particularly is in poor countries of advantage
. Since the structure consists of aluminum, no rust danger exists
· the vehicle exhibits partial clear customs traces, which do not affect functionality however
