It's been a LONG time since I've been here!
With the cost of fuel, construction finally finished, and a lot of tooling and material sitting around, I
finally pulled the bed about a month and a half ago, maybe two months now, and got to work! This first rear cage is fairly simple...it bolts down to existing holes, it's light gauge tube, and it's a lot of practice and learning experience.
This project is affectionately referred to as "Zip Tie Removal". The rear shock reservoirs and the brake prop valves were, until recently, held on by a bunch of zip ties.
Since the bed's gone, the weight bias requires two prop valves in series when the truck's empty, and barely one when full...the usual fuel/water/spare/tools/etc. that weigh ~800#+. In addition to a bracket for the valves, all the rear brake lines were hand-bent and located from the union under the driver's side of the cab to the soft line over the axle.
I also made a couple tabs to better mount the headlights to the fiberglass fenders, and fixed one of the smaller cracks in the fenders.
Then I got to bending tube!
The goal of all this was to drop the weight of the truck 300-500# (inner bed ~300#, tailgate 50#, Can-Back 80#, back seat 50#, carpet 20#, etc), more securely carry 30g fuel and 10g water, cooler, spare and tools, bring the bedsides in (ie dovetail), and achieve 14-16" of vertical rear wheel travel while mounting the shocks outside the frame (new rear axle is much wider than stock)--edit--which will make me feel a heckuva lot better about moving really fast across harsh terrain on large tires! There are already places here in CO where Katie and I have been, that normally require two or three hours to access on rough roads, we've been able to access them in under an hour.
Also flipping the shackle over will provide a more consistent spring rate, tho it will negate the benefits of Toyota's tension-hung design. The arc of the OEM shackle provides a benefit to droop, and a rising rate to full compression. I'm doing that part last.
Recent picture:
Sorry, that's all I got. At this point there are two braces at the rear, the top has a cross-brace, front and rear braces, and the first floor tube in front. Right now there's a 37" TA/KX, a cooler, and a couple gas cans stuck in there for fit-up...looks like I'll be able to do everything I wanted, plus carry two mountain bikes
. I have some old action shots but they're not hosted anywhere since TS recycled the photo gallery and I haven't had time to repost them. The bracing on top of the assembly should be good holding several hundred pounds, for example if I ended up carrying an extra cooler and water or whatever...and otherwise it's a perfect place to lash down drybags, snowboards, etc...
Looking rather seriously at Radflo shocks & hydro bumps for the rear. Many more ideas but it's all talk right now
...must finish this first, hopefully suspension cycled and shocks mounted some time in October...and there's still room for the shocks next to the cooler, if they have to go inside the frame after all.
Building this cage is quite a learning experience
. I still have a ways to go, before I'm comfortable building towards the design in the first post
