Lost Canadian
Sent you an email Scott.expeditionswest said:I left it out purposefully. I was concerned about the liability associated with the plumbing/fuel.
send me an email and I will shoot you the pictures.
Thanks
Very good question. I would like to know as well.Roemer1 said:Scott,
Now that you have had some time with this setup, Are there any do's or don’ts or “if I had it to do again” items that you could share?
Britt
expeditionswest said:These are not in any particular order, unless mentioned.
10 Greats
1. Suspension. This was without a doubt the single greatest improvement to the truck. It improved the ride, handling, trail performance and load capacity.
2. Gearing. I have no regrets going with 5.29's. Brought the truck back to life and gained 2mpg back.
3. Keeping the CG low. This was a goal from the beginning, and I stuck with it. Those who have driven my truck know how well it handles on the road and trail. Very stable.
4. Keeping the house systems and truck systems (mostly) separate. Nearly all of the accessories and all of the camp systems run off of the aux. battery.
5. Eezi-Awn Tent. It is my second home and still looks near new with almost 200 nights in it. Quiet, dark and a good mattress. I now have a system using the right bags to keep the bedding in it too.
6. HID. IPF HID driving lamps. Just trust me. Some people buy several pairs of lights and still end-up with less performance than HID and lots of watt draw.
7. Brake upgrade. Get the cross-drilled and slotted rotors and Porterfield S pads. I bought mine from Wheelers (good guys). I now have better than stock braking with a 6,000 lb. truck.
8. Rear swing-out. Heavy, but has saved me from big damage and freed up for the aux. tank and extra security.
9. Fridge. Gotta have one. Makes life so much better
10. Aux. tank No mess, no fuss and a 600+ mile range...
10 Not So Greats
1. Those big damn tires. A blessing ONCE (Rubicon), and a curse every other day. Can't wait to get back to a smaller size.
2. Installing the lights on the roof. Never needed them in the Arctic and it was a very big job. I might be able to use the mounts for a very light gear rack.
3. Trash... I forgot to design in a place to store trash. Ooops. So it now hangs on the back bumper or in little grocery bags.
4. Storage for gear. When I first designed the truck, I figured storage for the stuff I would need. NOW, I have computer bags, camera cases, more recovery gear, more spares and a few more systems.
5. Seating for three. I should have designed in seating for three from the start. I had a plan early on for three buckets and should have done it.
6. Navigation integration. I never really dialed that in. Need to.
7. Camera holders. I need to design in a way to easily store the cameras while in motion.
8. Electric water heater It works, but kills cheap inverters and still requires the truck to run after the first nights shower. I have a plan here.
9. Tool box layout. Didn't need the toolbox. Should have got a bigger Eezi-awn and mounted the battery and compressor at the frame level.
10. No camping protection from the elements! This has been the biggest revelation. If the weather is crappy, I have no retreat other than the Eezi-Awn. I should have installed an Eezi-Awn awning with the canvas sides. A place to cook and sit out of the rain, wind, sand or snow it much needed.
Also, my truck ended up too heavy (they all do). So, I am going to focus on the Chaser and remove some (actually a lot) of weight and complexity out of the truck and into the trailer. My Chaser is currently being completely reconfigured with some VERY cool additions.
Without a doubt, I am more impressed with this truck than any other vehicle I have ever built. It could be driven around the world, well off the beaten path, comfortably, reliably and economically, while return great handling performance (for a 4wd.) and braking. Then, it can go the complete other direction and drive the Rubicon with little drama and not a scratch.
I am not sure what my next rig will be, but the process of specification and selection will start very soon.
What I will do with the Tacoma is very much up in the air. Most likely I will remove lots of the weight and use it as a great business tool for trails, training, hauling stuff, etc. Or you might see it in the for-sale section...
expeditionswest said:8. Electric water heater It works, but kills cheap inverters and still requires the truck to run after the first nights shower. I have a plan here.
:iagree:crawler#976 said:That pretty much sums up years of trial and error into a single post...
