Explorer tire choices.
KLAKEBRONCO
I'm kind of looking at tires right now, and would appreciate any feedback or suggestions.
The stock size on our 2001 Explorer is 235/75/15, but am looking at my options.
My priorities include
  1. Price
  2. Longevity (highway mileage treadwear)
  3. Effects on MPG
  4. Traction (especially wet rock/cement)
  5. Smoothness on road (Note not noise as I can tolerate some noise)
  6. Winter traction on snow/ice
  7. And to top it all off mud traction since any offroading will be muddy most likely
I would like to look at a very moderate height increase. At 70-75mph on the highway I'm at 2500RPM, and I really think the power to weight ratio of this truck would allow me to run at 2000rpm at that speed easily.
So far as I can tell I'm looking at stock replacements of the 235's with a more aggressive A/T tread pattern
A 30x9.5x15 or 31x10.5x15
And if I make a wheel swap (which I would rather not do simply because of cost-I want to stick with aluminum for weight savings) a 245/75/16 or a 235/85/16.
I would think that I would get great tire wear out of the 235/85/16's simply because they are a higher load range tire which I've always equated to longer wearing when used on a lighter truck. (I don't like the idea of increasing harshness though)
245/75/16's seem to be really common, and this might be the best size but I would need new wheels. Maybe some factory 16" wheels can be sourced for a good price.
31x10.5's seem to be the most common, but I'm concerned about the extra width hurting MPG more than my other options. These seem to run a little cheaper than others.
duckhunter71
I'm about to put a set of Cooper Discoverer A/T3s on my Frontier. I had a set on my 99 4Runner before I sold it and absolutely loved them. They rode good, looked good, and had good traction. I believe mine had 10-12k on them when I sold the 4Runner and they still looked absolutely brand new. They've got a 55k mile warranty one them, so I expect to get quite a few miles out of them, as well.
Those were 265/75-16s.
dddonkey
I would look at the Goodyear Duratracs, I had them on my wife's Jeep Commander and that thing went everywhere I wanted it to. I am looking to put them on my truck when the current tires are worn out.
4x4junkie
I would also be afraid of the tire not gripping as well, especially on wet rocks (stiffer carcass not conforming to the terrain as well, and probably a harder rubber compound to help support it's higher load rating).
I also have heard a lot of good word on the Duratracs, I'd 2nd those maybe in a 30x9.50 for a slight height increase, or the 31x10.50s for something a little more substantial. Running about 30-35 PSI, your MPG (and treadwear) should be pretty decent.
Revco
I had 70k on a set of 235/85/16 Cooper Discoverer ATR's and they still passed state inspection. I loved those tires.
legendaryandrew
I'm partial to Toyo M/T's. They're a bit heavy, but they wear slow, and they're great in mud. Plus they seem to grip pretty damn good in snow/ice if you have them siped. I did on my '97 FZJ, and the thing was amazing in the winter. Maybe even better than my Evo's Blizzaks.
brianjwilson
Some sort of lost...
I ran 31x10.50s on my stock 97 Explorer 4x4. That particular truck had 3.73 gears, the OHV made decent low end power. If you have taller gearing (3.55) I'd think about a smaller size. The 31s weren't much worse than stock (generally terrible) for mileage.
15" tires are generally cheaper and the proper load range (C).
Mitch Bears
