ExPo Nissan Registry
SpongeX
Rust does a body good.
Very nice. I'm jealous of the roof rack. I'd like to get one so I could carry a tent in the event we don't bring along my wife's Xterra. I'm waiting to see how it all pans out with Xoskel though.
Sent from my VS950 4G using Tapatalk
Ghost65
Allergic to Pavement
At this point, I'd go with a GOBI. John makes great products, but the wait time is a serious drag.
skibum315
Hah ... I know that guy (DzrtX) ... :friday: ... what's shakin' John?
Sponge, since you're semi-local, Gobi's even more of a no-brainer ... they're down here in Commerce City. Get it ordered up, and when it's ready, I bet they'd even help you install it at their shop (or at the very least, just make the drive over and save yourself the shipping time - and some cost). They were awesome to me (& my wife) when I got my rack ... they're good folks over there.
I'll put together a more interesting post at some point, when there's more interesting stuff to look at, but for now here's my (short) list:
2008 Xterra Off Road 6MT
255 Toyos
Maxterra rock rails
NXRocks skidplates
Uniden 538w CB & K40 hood-mount whip
Gobi Rack (they're Eagle Eye lights ... need to spend some time on the electrical, though)
recovery/safety/emergency gear as needed
... and a whole pile of parts sitting in the garage waiting to go on ... :snorkel::coffee:
1st off road trip with it, 2009 ... bone stock (started the trail with mudflaps, even ... didn't finish with them, though):
GONE 2010:
GONE 2011:
richard310
pew pew
Updated as of July 30, 2015
Thought I'd bring this thread back to page 1 and finally contribute here :)
Year: 2004
Model: Xterra
Trim: XE
Drive train: 4WD
Transmission: Automatic
Mileage: 177,xxx miles
Color: KY2 Polished Pewter Metallic
Tire Size: 265/75-16
Engine/Transmission:
- Nismo SS Catback Exhaust
- Nismo K&N Cone Filter (removed and swapped for OEM air box)
- NGK Spark Plug Wires
- Mean Green 180A Alternator
- Supercharged Xterra Radiator
Major Maintenance:
- Timing, A/C, Alternator, Waterpump, Power Steering Belt (11/2013)
- Spark Plugs/Distributor Cap (11/2013)
- Water Pump, Thermostat (11/2013)
- Crankshaft/Camshaft Seals (11/2013)
- Replaced Leaking High Side A/C Line (6/2014)
- Replaced Driverside Axle (8/2014)
- Replaced Starter with Ultima Remanufactured Starter (8/2014)
- Replaced alternator with rebuilt OEM 100A unit (12/2014)
- Rebuilt Alternator took a dump, modified pulley and installed Mean Green 180A Alternator (2/2015)
- Condenser to Compressor line replaced (2/2015)
- Front and rear diff fluid drain & fill (2/2015)
- Induction Service (TB Clean, Manifold clean, everything pre-engine was taken apart and cleaned) (2/2015)
- Replaced LCA balljoints, steering tie rod ends and balljoints: PRICEY! (3/2015)
- Replaced Calmini UCA balljoints (3/2015)
- Replaced leaking radiator with Supercharged version (6/2015)
Tires:
- BFG AT KO's Load Range E, 265-75-16 (retired)
- General Grabber stock spare (retired)
- Cooper ST Maxx Load Range E, 265/75-16 (32")
Suspension/Brakes:
- Bilstein HD 4600 for 3inch lift
- 4x4Parts Front Sway Bar Polyurethane Bushings
- 4x4Parts Front Sway Bar Polyurethane Endlink Bushings
- 4x4Parts Rear 3-leaf AAL
- Calmini Extended U-Bolts and Hardware
- Calmini HD Upper Control Arms and Ball Joints
- Calmini Idler Arm Brace
- Firestone Lifetime Alignment
- Powerstop Slotted and Crossdrilled Rotors
- Powerstop Scorched Evolution Pads
- Raybestos Rear Drum kit
- (REMOVED) Pro Comp ES9000 Shocks
Exterior/Armor:
- Trekking OASIS II Roof Top Tent mounted on OEM roof rack
- Calmini modified rear dual swing out tire carrier
- AT NATO can holders
- Deustcheoptik NATO 5gal/20L jerry cans
- Hi-Lift 48" Jack
- ARB 1250mm Awning
- ARB 1250 Awning Front Wind Dam
- White Knuckle Sliders
- Xoskel Light Cage
- Nokya Arctic Yellow 9007 Headlight bulbs
- BlitzPro 6LZ 6" Roof Rack Lighting
- Generic 32.5" 180W Combo LED Bar
- Generic 6.8" 30W Combo LED Bar
- (REMOVED) Rugged Ridge 6" lights with 3000k HIDs
- (REMOVED) Tuff Stuff 4.5" HID 6000k
- (REMOVED) Hella Rallye 1000 Black Magic 55W Lights mounted on stock bumper reinforcement with Nokya Yellow H2 Bulbs
- (REMOVED) 32" LED Light Bar 18,800 Lumens mounted on Xoskel Cage
Comms/Electronics/Interior:
- Midland 1001LWX with NOAA CB Radio
- Firestik SS204A Mount
- Firestik II 3' CB Antenna
- Kenwood TM-281A 65W 2m Radio
- Diamond K400S Mount
- Diamond NR770HB Antenna
- Lowrance GlobalMap Baja 480c GPS
- Red LED Dome lights
- DepHep Rear Window MOLLE Panels
How it sits today:
Jack Stilts
Subaru Ambassador
My turn, suckas.
Year: 2002
Model: Xterra
Trim: XE
Drivetrain: 4WD 3.3L
Mileage: 80K when purchased; 105K current
Color: Silver Ice with blaccents ;)
Modifications:
[x] K&N filter / trim repainted
[x] Rear sway bar, side rails, and resonators removed
[x] CB install / LOBO / custom headliner / stereo upgrade
[x] Gobi ladder and Dephep rack
[x] Xoskel lightcage & LED bar
[x] Xoskel rear bar with CHMSL & Hanma LEDs / alley lights
[x] RLC armor - front bumper with PIAA fogs & amber LED bar; rear bumper and tire carrier
[x] Rock sliders & OEM mud flaps
[x] Safari snorkel
[x] Rear differential breather mod / rear hatch raiser mod
[x] Quest alternator / Supercharged radiator
[x] Total Chaos steering system upgrade (centerlink, heim joint tie rods, idler arm, pitman arm)
[x] 3" suspension lift (upper control arms, heavy duty torsion bars, rear add-a-leaf, Bilstein 5100s)
[x] Desert Runner wheels with 32" BFGs
Build thread link (full build thread from XterraNation is in ExPo thread)
geordie4x4
Geordie's Australian Nissan Patrol
Well it is interesting to look through this thread at all the Nissans and see that you guys are not only into Jeep's over there. Seems that there are very different models in the states to Australia.
I have a 2005 Nissan Patrol GU Series IV.
3L turbo diesel, Auto Diesel/Gas injected
front and rear airlockers
long range fuel tanks 215L diesel and 30L gas
285/75x16" ATZ
Full Firestone airbag suspension for 4" lift
Kitted out for long distance touring, camping, boating, fishing.
I wil add some more details of the mods later.
Here are a few of my rig
Traveling the Red Centre of Australia
Out on the beach with fishing kayaks.
With the camper trailer, some new wheels and Hobie Tandem Island on roof rack.
This was my previous Nissan, a 1992 Pathfinder 2.7 turbo diesel. Japanese Import model Terrano
SpongeX
Jeeps are for people who don't know any better. Nice patrol. I wish we could have them in the states.
Camelfilter
All above very nice!
Here is mine (no build thread though, sorry!)
2013 Nissan Titan Pro-4X.
Mods (so far):
-Bilstein 5100 struts middle perch.
-.85" front level spacers (combined with struts gives about 2.5-3" front lift)
-Bilstein 5100 shocks rear.
-Firestone airbags rear, manual pump (bicycle pump), fittings inside bed toolbox.
() some type of mini level/lift for the rear, probably via shortened shackles-will add 1".
-BD tuner ram mounted under rearview.
-Nismo true (cat back) dual exhaust....Little loud.
-AirRaid CAI dry filter(non-oiled), with water "proof" filter overlay liner.
-FlipPac.
()Currently am still mid-torsion bar delete.
-Drawer/slide for chuck box & another drawer/slide for fridge.
-Near cab bed storage bench half done.
-Rear high mount stop light for FP glass.
-Rear hitch mounted step/bash guard.
-Cobra dash camera, records 3 hours in 3min clips, then over writes the oldest.
-Front & rear armor, rear has 2 swing outs for 20L gas + 20L H2O + LP tank. Was made by Outdoor Logic out of California (I don't think they make armor anymore).
-Supersliders (RR rock sliders) installed (bolt-ons). Need to have them welded on at some point.
-Rocky Road "Shock Rock" kit. Like sliders for the shock mounts + add an inch or so to the shock (don't have to buy longer shocks if a small lift...).
-House power: sears die-hard marine, isolated (was solar charged, but I left the removable panel on the roof one night & drove to work...)
*Now I "simple" charge it with a 10A/2A charger before a trip, & while driving during a trip (my truck has a 110 outlet in the bed).
()on board dual battery charging using the alternator (not sure which system to go with yet).
()aftermarket grill so I can easly relocate & service the winch solenoid/control box + do behind the grill lights.
-Played with black (front grill) & red Plasti-dip (lettering) for fun...
ilciclista
