If you have oversized tires, I say maybe yes.
I found that my truck rubs a little during compression at speed. It was not really hurting anything, but becomes annoying after a few days.
I first installed polyurethane stops. They were a little shorter, but denser. They may have worked. I have a friend testing them now.
I picked up some used bump stops. I picked up a whole bag of various stops that I thought might work. They are cheap at the salvage yards. No one ever wants those.
Left to right: GM PART # 15712438 $11.08 each (new). These are off of the rear of late '90s and early 2000 Chevrolet fullsize pickups.
Next is the stock bump stop.
Last is the Energy suspension Part # 9.9101G $11.99 pair.
The first set has a hole in the center.
This would have them act much like a rubber spring. The front of the fullsize uses the same design , but the mounting cup is welded to the chassis. That is why I chose the rear stops. They are a direct bolt in installation. I know the fullsize ride on the stops all the time. There is no clearance on the a-arm.
A little increase in spring rate would be nice since I have torsion bars and no real options there. That is my thinking right now anyway. This might just be the answer. They are soft. Not as soft as stock, but flexy. It works for the fullsize, why not ours? This would be a gradual increase in rate. As they compress they exert resistance. Not as harsh hopefully.
I added a comparison shot of the polyurethane bump stop mounted.
You can see that even with the 1/8" thick washer to space it down a little there is quite a space. I don't think that is bad. I do have some reservations about them though. Harder may deliver more of the forces elsewhere. They might tend to stress other bushings? Steve mentioned that he ruined a set by over torquing. What if I pound them? They might crack and break out just the same?
Now that things are being upgraded for the front, what about the rear? I only had the rear rub a couple times, but heck what if I want to really jump this thing? Time to look at that too.
On the left: GM PART # 15023225 $21.76 each (new). These are off the back of a late '90s Chevrolet Tahoe. They are Polyurethane and solid. No hole through these. As you can see they are quite a bit longer than the stock ones. The rear has been raised more than the front though, so this may be a better match.
As you can see they are a different design. They can be slid into the channel for the stock stops and with a little work, can be tightened in place from above.
I jacked one wheel up as far as my jack would and it did not touch. the tire had a couple more inches to rise yet and the stop had over an inch. These too are flexy. not as much as the hollow fronts, but still should offer some cushion.
I have not pounded this fully loaded yet, but I have bounced it pretty good offroad with the daily driver loads. They work great.
