Extending Cab over on grandby
GoinBoardin
Some form of polyurethane construction adhesive from home depot, nothing too fancy. My interior panels are just a plastic sheet type material, seems to hold fast.
BajaSurfRig
@GoinBoardin is there a trick to finding the interior vertical framing members?
From what I can tell the front two verticals line up with the windows so those should be easy.
It looks like the passenger side vertical above the window isn't as easy to locate?
Do you have the dimensions to the second framing member you screwed into from the front of the camper.
I am trying to avoid drilling pilot holes into the camper walls until I find the framing member.
Thank you for all of your help!!
AZXPLOR
