tanuki.himself
Starting a new thread away from the questions about extending vehicle heat/coolant circuit to the camper....
Could you extend the vehicle cab air conditioning to the camper space?
I'm thinking could you take a dash aircon matrix (evaporator) and blower fan from a scrap vehicle, fit it into the camper and run pipework from the vehicle aircon compressor and matrix (condenser). And coud you use dry break connectors on the pipes to keep the camper demountable?
I'm looking for a cheap. lightweight solution to cool the sealed camper while driving and. more importantly, cool the over-cab sleeping area after sunset before sleeping - should be easy to curtain this off to keep the cool to a confined area. I'm planning on using 12V solar and battery for refrigeration anyway so don't want to add the load of a 12v or inverter aircon unit to that, plus they tend to be heavy and expensive. And carrying a generator is more weight and space...
If you could select between cab dash and and camper aircon matrices with manual or solenoid valves and then just run the engine on idle for half an hour would that do the trick?
or even use the dash evaporator from one of these kits in the camper
https://www.ebay.com/itm/New-A-C-Un...Serpentine-Compressor-CO9537CKB-/173287712010
but still tie it into the existing vehicle compressor and condenser to save weight ....
