F150 overland build
Raul B
Here are some pictures of the mount I just finished. I'll get some better pictures tomorrow after its painted.
Sent from my SGH-T989 using Tapatalk 2
dave1014
Raul whats one of those decked bed boxes cost for my superduty? You know where to find me.
Sent from my SCH-I925 using Tapatalk
Raul B
here are some updates from this morning.
I drilled 4 wholes through the plate first.. then i alligned everything and used the plate to drill the wholes through the factory dash plate.
i then put the nuts on. this worked out perfectly because by the time i put the "liner" piece over it its completely flush with it. this will make it so i can take it off whenever im not going to use it and on again very easily.
im pretty much done with it. im just giving it a few coats of paint right now and once it dries ill post up some final pictures of it mounted up
-Raul
Raul B
ok so today i didnt get a whole lot done but i got some more cross bars installed the rack, i sanded it smooth with 80grit (going to go up to 150 grit before i paint) and i added my light mount tabs for the 50" light bar that came in the mail today....
Raul B
Today's progress so far:
I finished grinding and sanding, added the angle pieces that go from the top bar down to the bottom near the light bar and i have done 2 coats of primer so far. Im going to let this set up overnight and do a few coats of satin black tomorrow.
DragonX
I was able to stop by and give Raul a hand today with the rack.. It's really coming a long nice.. Snapped a quick pick of the point of no return...
Deleman
