Viggen
Just here...
So, my 95 Disco with an all stock 3.9 just failed smog inspection. Its registration time so I am in need of it to pass to get my little stickers. Its running rich. Not just a little but a LOT. On the bright side, this would probably explain the crappy fuel mileage Ive been getting lately. So, here are the numbers:
HC ppm:
Idle: Limit- 125 Reading- 432 (Go big or go home? They sent me home)
2500: Limit- 125 Reading- 253 (leans out under speed but not nearly enough)
CO%
Idle: Limit- 1.00 Reading- 0.91 (Just barely under the limit so a pass)
2500: Limit- 1.00 Reading- 0.90 (Again, leans out just a little at speed)
Everything else is a pass. The guy looked at the numbers and was astounded and as was I. So, where to begin? O2 sensors Im assuming and thankfully, there are only two of them and not 4 like later Discos. What else could it be?
Im planning on a diesel swap but thats about a month away so I need to get this beast through.
HC ppm:
CO%
