-Red_beard-
Classic slide in for an 8’ bed truck. I’ve had it on a 2012 ram 2500 at the bottom you can find measurements to determine fitment per your vehicle. This camper has been freshly renovated with staying off grid in mind inside is new everything from tounge and groove throughout to the cabinets. Max air vent fan, small articulating 12v fan, multiple 12v outlets, 30gallon water tank with a quiet flow pump, a propane camplux tankless water heater, two 34 agm odyssey batteries powered by a 300w Renogy system and a genesis off-road dual battery setup that also ties the system into the cranking battery and alternator for those cloudy days. Ample storage throughout with 3 burner stove and sink. There is a small 24x24 shower inside and a fold down frame to hang a curtain from outside with and easy to reach water spicket. Low draw led mini can lights on a dimmer, fridge pocket on drawer slides designed to fit dometic dual zone fridge/freezer(fridge not included) The seating was designed to fit two mad rock bouldering crash pads, the external aluminum rack was made to support in excess of 600w of solar and hang mountain bikes off The back via fork mounts. This camper is great if you want to travel and bring gear for numerous sports. 8 weeks with gear for surfing, biking and climbing with room to spare. The outside was not touched it keeps unwanted attention down.
Asking $5500 obo delivery could be negotiated. Located in the four corners
Bed to bed rail 20”
Wing to front (cab) 99” 3/4
Rear to front (cab) 128”
Overall 176”
Width 85” 1/2
Height 84” 1/2 ( this is the only measurement including the aluminum rack)
Bed to bed rail 20”
Overall 176”
Width 85” 1/2
