TeriAnn
I'm no rover guy, and just drool over them here... I have to ask for my knowledge, is the darker green dorm fender's cut? Seems like it has a different cut than the other two pictured above.
The outer wing panels are stock European spec mid 1980's Defender. They bolt right to my 1960 Series inner wing panel and the bulkhead. That version of the outer wing panel does not have holes for side lights. All the others do. I had to make the cut for the Kodiak heater intake.
Defenders make good sources of parts for Series Land Rovers when the original Series part is NLA or you want to upgrade something. In my case I wanted a larger wheel cut out. The down side is that often the Defender part is inferior to the Series part. Like these genuine Land Rover wing panels are stamped from a slightly thinner alloy that is not as good as bermabright. It seems more susceptible to oxidation and I think it is a slightly softer alloy.
