I searched the forum for an answer but couldn't find one. I'm beginning the fender portion of my expedition trailer build and am trying to figure out if I have enough clearance between the tire and fenders. I had a smaller tire on during the build and when I realized that the tire that i'm planning on running is bigger I panicked. There is about 4 inches of clearance between the top of the tire and the fender and about 3 inches between the front and rear sides. I'm running a 3500 lb axle with 2000 lb springs. The fender is currently just tacked together and I can move stuff around but would prefer not to if I have sufficient clearance. Does anyone know how much movement the tire would make horizontally when it's flexed? I assume as the springs straighten from added weight they will move back some.
Here is a pic of the current layout of the fenders:
Thanks,
Justin
Thanks,
Justin
