I absolutely agree with this suggestion."wait till you finish your camper build out, then do the suspension"
Any thoughts on the automatic transmission?
I drove mine home from NC to Denver with no load and 80psi in all the tires. Talk about a nightmare. I began looking at every bridge joint with sheer terror. A camper, timbrens and new shocks solved the problem. Mine comes in at around 11,900 lbs with the full service body, Northstar TS1000 camper and fully loaded for camping and extended canoe tripping. I run 60psi in front tires and 40psi in the duals. (based on a tire company's load v psi chart) Get yourself a utility body, slide in a truck camper and you're good to go.You are correct. 6'1". The drive from NJ to NC USA should have included 1000mg Ibuprofen. I do plan on suspension improvements, super singles & tires and other typical improvements read about here on the forum however, I want to do a full "bed off" assessment prior to anything else. The frame appears decent...much better than the first FG I looked at. The mechanic I had inspect it gave it a thumbs up. He said I will need to plan on new engine mounts in the near future but it wasn't a terrible problem at the moment. Once I get the bed off I'll probably tackle the engine mounts (which means find someone to do it for me). I lack shop space and knowledge regarding most things FUSO or motorized for that matter. As much as I'd like to throw the $ to cool looking wheels and tires I need an overall game plan. Once the bed is off I think i'll be able to better understand camper potential and design. Since a camper is my end goal, I need to work that direction in baby steps.
I thought the Fuso automatic had a pretty large cooler with its own electric fan mounted forward of the batteries on the left side? At least I've seen a few that way. When I bought ours, the dealer had two identical trucks with the same mileage, one standard and one auto. I chose the standard. Your friends experience confirms the wisdom of my choice. We drive in the Rockies a lot. I want even more gears than 5, not fewer.We had friends with an auto transmission model of the same year fuso on their expedition truck. It had fewer gears than the manual making an already slow truck into a glacially slow vehicle. It was leaking very badly so they had a supposedly reputable shop do a complete re-seal of the transmission. It failed completely two months later on a hundred degree day pulling the hills out of death valley with no warranty coverage. Replacement was horribly expensive. If you keep the truck light, mount a significant transmission cooler, and use caution in very severe conditions you will probably be ok.
Personally, I prefer manual transmissions in all of my vehicles.
Allan
