skippythedog
RE: 2007 FG 140:
What can we do to improve the interior comforts of the FG (aside from seats, window tint, insulation etc.)?
In particular, I'm referring to the electrics and trinket storage...I figure I need at least 3-4 12volt plug ins (gps, phone chargers, dash cam etc.) in addition to the cigarette lighter which is in a poor place to plug stuff in anyway.
What's the best way to do this? I thought I'd run a big bus bar w/ a cable back to some big amp connection on or near the battery....or is there an unused fuse that will support 3-4 of these low amperage accessories?
Are there any places on the dash (inside the passenger cubby/shelf perhaps) to mount some cigarette style plugs?
Any tricky blind trim screws or tabs that make it difficult to pull the plastic out of the cab?
Any part numbers for switches that fit the dash holes?
Does anyone make a console that retrofits overhead?
Will the screws or metal supports in the cab roof support something like that? Molded from Kydex maybe?
Is there a cool way/location to mount 2 more speakers?
Is there a way to add storage?....I was thinking of fabbing up a shallow, wide nylon bag that would hang behind the passengers feet at the base of the bench seat, or perhaps a small console suspended across and just above the dash between the lower grab handle screws...
Thanks for reading this far....here's my little trick: I replaced my grab handle screws with this 1" ball mount by RAM, replacing their 8mm bolts with 6mm Allen bolts w/ an aluminum washer......a swiveling drink holder by RAM is the first big benefit for the passenger..... https://youtu.be/Pmc4kOuZSN4
