Finally bought a U500
bigmellon
Get that beast home yet???
BTW - You can tap the onboard air system to run air tools. Not 50+ CFM but it will run more than my home compressor.
Figure out what that thing in the middle console was yet??
Thanks, I wish it was 9900lbs. With the bed I believe it's 16,700. I don't know what the cab chassis weighs. Almost all of the U500 in this country are 33,000 GVWR. I didn't really appreciate the high GVWR until I started to run the numbers. It allows the capability to carry the heavy liquids to stay out without resupply: beer, water and fuel. I really like that I can consider 200 gallons each of water and fuel while keeping the GVW under max.
Every other option I look at was weight constrained. The U500 is volume constrained. Actually this constraint would make a hard sided popup the best choice. I just don't know if I want to add that complexity to the build time.
From what I've seen a hard sided popup with the bed is above the kitchen is a considerably bigger camper than a standard camper at the same length.
Anyone with a larger camper please add what has worked well and what you would change.
According to Unimog NA's weight spreadsheet my cab-chassis weighed 3800kg front/2400kg rear. Since it's now 4350 front and up to 8500 rear, that's a useful payload of 6650kg = 14663 lb.
The rear axle is actually plated at 9000kg and the tires can be overloaded to 12300 lb:
http://www.dodgroundtires.com/pdf/SAA_Letter.pdf
Charlie
dterrell
