...to start installing a dual battery system in my '07 Silverado Classic. I'll be using Blue Sea terminal fuse blocks and fuses to protect the house and starting batteries. My plan is to run the following accessories off the house battery:
What size terminal block fuses should I be using at each battery?
Many thanks, in advance.
Smoky
- ARB 50 QT fridge/freezer in extended cab with back seat removed
- Mounted in bed of truck...Blue Sea 6-fuse circuit block w/negative bus, 2 Powerwerx 12V Cigarette Lighter Socket , and 1 Powerwerx 12V USB charging port
Smoky
