toyrunner95
ok so i bought my 84 toyota pickup a while ago, and it had a few issues. like the bed, some of the wireing, how things were set up under the hood. just a bunch of stuff.
its taken me 3 years to sort through all that stuff and i think i finally got what i can taken care of. SO ill tell the stroy as i go.
well since im actually making money this year, me being a college student and all, i finally have some spending cash to put into the truck.
this weekend i decided to make an overhead CB mount which was actually really easy. its just a piece of flatbar with bent ends to match the coutour of the roof. i dont have any upholstry so the install is really simple, however i believe that this same idea could be used with the interior still inside. you would just have to be a little more careful. after i bent the bar in a vice i drilled a couple holes in each end to attach it to the roof. as for the CB i welded on a little wing or fin or whatever you want to call it for the bracket to mout to, this placed the flat bar to the right of the dome light and the cb right above the mirror.
the next move was to finish the bed i had made last year. i used a fluxcore welder and i didnt really take the time to pretty up the welds, this year i bought a lincoln 135 gas wirefeed welder and WOW are that thing slick. the welds are almost perfect and alot stronger.
lastly i got to work on new tires. i originally had 35x14.50 super swampers. they are great if you dont mind paying for tires every year. the tread is really soft and has a tendancy to "chunk". so i called up four wheel parts and found some BFG 35x12.50. skinnier yes but they helped my steering greatly. with the 14s i had the turning radius of an aircraft carrier. it was terrible.
speaking of steering i finally got around to finishing my U bolt flip kit. the rear i had done but the front never got finished. so i went about taking all of the u bolts off and painting the plates, something i neglected to do last year due to time constraints. However; when i got the the driver side front i encountered a problem. the u bolt hits my crappy old j arm steering.... situation. so i finished up the passanger side and decided that i am going to put a hysteer kit on it anyway later this year (hopefully) so i will just put on the old u bolt plate for time sake and hassels.
thats it for day one of memorial day weekend, stay tuned for day two!
