First post 2000 RR 4.0 head gasket replacement
cdclpc
It will be the weekend before I have a chance to get back to it. Thank you for your help and I will update as soon as I can.
getlost4x4
Same thing happened to mine, minus overheating. Around 155K miles. Its now at 167K miles. Fixed mine 6-8 months ago. I didn't even machine the heads. I should have, but I had a time crunch. so far, its been okay. next time it blows, it gets a compete rebuild to a 4.6L
The fire ring on the cylinder blew out. I replaced pretty much all the gaskets and seals on the top end. Took me about 10 hours in total with lots of cleaning. I replaced the valve seals as well and the head bolts. bought my kit from BPUtah.com for around $215. Its a Victor Renz kit.
cdclpc
That sounds more promising than I had expected. I think I'm going to get the heads off this weekend and have a look.
sydneyman
really not that hard. i would advice going to studs rather than the one time use torque bolts... plenty of room to work and parts are readily available. nothing more satisfying than a top end rebuild on a push rod v8. super simple.
cdclpc
I've done many head gaskets before. Push rod or otherwise. The possibility of having other issues that are common with this particular engine is what had me concerned
TexasTJ
Climbing Nerd
Only one way to find out. Crack it open...
Clemtiger84
