First trailer build!
b63215b
If you looked at my thread for my hand built roof rack I made some drastic changes thanks to some folks suggestions. Let me know what you think.
Sent from my SM-G920V using Tapatalk
b63215b
Admiring my handiwork right now, took a break for the trailer to finish this till my pop pins arrive for the trailer.
b63215b
Just messing around with my 4runner spare soon the trailer will hopefully have a matching set like the 4runner.
b63215b
Pop pins came in yesterday for my sliding RTT rack to stay in place. Will have a high level and a low level.
So here is the internals of the pop pins it has an 1/2" pin that is around 5/8" in length.
b63215b
How I have decided to lock the side fold down doors. It's just a hitch pin lock.
b63215b
Holes drilled for all pop pins top and bottom position. Also worked on mocking up thr gad struts. Takes some thinking.
b63215b
Nice upgrade today found a set of wheels and tires for $80 good amount of tread for a trailer.
b63215b
Struts on, they were a PITA to push down without the weight of the tent on it.
They are both 100lb struts, likely why they are so hard to push down with weight on it. I still have a feeling its going to be tough to push it back down. But I had the large laying around rather than buying a new set. Thanks for the idea box rocket.
b63215b
Here is the near final product. Still needs its legit bed liner but that will happen later.
b63215b
Build isn't done but finally got to enjoy for a full week of overlanding, dispersed camping (free) in thr UP of Michigan logged over 2000 miles on the 4runner at 230,000 still running strong
b63215b
Found a place for the high lift on the trailer welded Grade 8 bolts to the uprights for the tent lift. You csn see how I did it below.
It was getting to be a pain with the Jack inside so this will help a lot.
Now just a strap to hold the handle.
vertical.dan
