FJ Cruiser test ride today
Biker Eagle
Really nice used 2007 FJ 4x4. One possible problem. When shifted into 4 low engine RPM's would rev to 2500-2800 before drive engaged then it would move out and Rev again before shifting to the next gear. Normal or problem?
D
Deleted member 13060
Guest
Problem, find another. When in low range my 2011 will climb a tree at idle.
1Louder
Ditto doesn't sounds normal to me. Too may four wheel vehicles are never put into 4 wheel drive and then problems occur.
Kevin108
On rigs with real transfer cases, you are almost always supposed to shift the transmission into neutral before shifting the t-case into 4 low. The FJ is no exception:
Page 137 http://brockandbecca.com/files/fj/FJ_Cruiser_Owners_Manual.pdf
SHIFTING BETWEEN “H4” AND “L4”
Stop the vehicle, put the transmission into “N” and move the front drive control lever.
Dalko43
As opposed to fake transfer cases?
I get the real vs fake transfer case you're pointing out there, but he does make a valid point about shifting into Neutral prior to engaging and disengaging 4wd Lo.
OP, were you shifting into neutral before engaging and disengaging 4 Lo?
Kevin108
As opposed to the viscous variants and some of the vacuum or electronically-shifted cases. I'm not familiar with enough of them to say EVERY transfer case requires the vehicle to be in neutral to shift to 4-low. I colloquially referred to them as "real" transfer cases as that's how those of us who've spent our lives with manually-shifted lever-operated transfer case tend to feel about them.
toylandcruiser
Still a transfer case :). Functions exactly the same. Viscous is very reliable. Look at Subaru. I've spent my life with manual transfer cases and have no issue with electronic shift. To each his own I guess.
Kevin108
My wife is in a 2012 Ford Escape. It's on of the viscous setups that works automagically. I like that she doesn't have to know when to shift into 4-hi or when to shift out. It just works.
I was primarily telling the OP that when it comes to shifting a manual t-case, he's doing it wrong.
RoyJ
Could be wrong, but I believe all electronically shifted transfer cases need the transmission in neutral as well before going from 4Hi to 4Lo (Range Rovers are the only exception I know of). Internally they're the same, just a motor shifting instead of hand lever, and neither can shift with the transmission in gear, putting torque on the input shaft.
I don't think that was the OP's problem though - if he had it in gear he won't be able to shift into 4Lo without grinding like hell. But once you're in, the transmission shouldn't all of a sudden start slipping between shifts. You're either in 4Lo or you're not, it shouldn't delay vehicle movement till 2500 - 2800 rpm...
Kevin108
It is possible to force an FJ into 4-low while in gear. Lesson learned: don't let other people drive your stuff. lol
But what I got out of the OP was. "When shifted into 4 low engine RPM's would rev to 2500-2800..." As in shifting to 4 low, bypassing neutral, caused the RPMs to rise.
Biker Eagle
Crossing the Rubicon
As it turned out it was operator error. Shifting from park not neutral.
Went back for a second test drive after reading the posts here, and all performed as it should. Thanks for the insight, otherwise I would've missed out on a really nice FJ.
Instead, I crossed the Rubicon yesterday. Sold my Wrangler TJ at 3:00pm, and left for the Dealer where I consummated the deal on my FJ by 6:00pm.
The Black Beast resides in my driveway tonight. Let the adventure begin....
WonaWarrior
