I was lucky enough to find a M416 trailer on Craig's list. It was pretty rough, but solid enough to be well worth the $400 the guy was asking. I called about ten minutes after he posted the and wet to see it immediately. Good thing because the guy said about five people called right after me and offered to buy it sight unseen. He was a stand up guy and gave me first option to buy.
I've been looking at a lot of build threads posted here and some of you guys are amazing fabricators. My trailer build won't be that elaborate, but it will be done right and will be a nice trailer when I'm done.
I've been meaning to post this for a while, so the build is pretty far along. I'll try to update it as I proceed.
Here's how she looked when I bought her.
As you can see, the tailight is broken. Bummer because I was hoping to re-use them. Oh well, I'm not trying to do a restoration anyway.
All broken down ready to go to the sand blaster and then powder coating. I was surprised just how solid the frame was. Aside from some rust pitting on the tongue arms, there was no other real damage.
Fast foward a few weeks and its back, and I have to say, it looks brand new. Looks a lot better than I was expecting.
Now that the frame parts are looking good, the tube and fenders are off to the sandblaster and it's time to start putting the frame back together.
I was planning on re-using the spring shackles, but the rubber bushings were toast and I couldn't find replacements. Plus, the grease nipples were pretty clogged and weren't replaceable. Morris 4x4 had new shackles for fairly cheap, so I just ordered new ones. The inserts were in good shape, so no need to fight that battle.
The U-bolts that go around the tongue arms and connect the tub and parking brake were toast. The threads were rusted pretty bad. So off to the internet to find replacements, but after an exhaustive search, it appears that they are un-obtanium. Apparently, 7/16ths rod is not a common for U-bolts. Who knew?
So now what? After much searching, I found a local shop that specializes in truck springs and they were able to bend a couple up for me. Cost me $12 bucks I think.
While I was painting the freshly bent U-bolts, I went ahead and painted all the washers. I purchased all new hardware, but being the cheapskate that I am, I didn't spring for new washers. Stupid, I know, but a dollar is a dollar.
All painted up.
Now for the Axle decisions. The old axle was in decent shape, but lik everyone else, I wanted to run the same size tires and wheels that are on my Jeep. That means either adapters, or a new axle. Since the hand brake was already missing and I wasn't doing an accurate restoration anyway, a new axle was a no brainer. For what it would have cost me to replace the hand brake mechanism, rebuild the brakes and bearings, I was able to purchaes a whole new axle with electric brakes. A quick call to Red Neck trailer supply and a 4 day wait I have a brand new axle with a 5 on 4.5 lug pattern and electric brakes.
Came with a crappy paint job, so I stripped it down, primed and rattle canned it. Had I had it sooner, I would have had them powder coat it. But, I'm making this up as you go along, so it is what it is.
New axle U-Bolts meant that the old plates with the shock mounts no longer fit. I decided that instead of modifying the old plates, it would be quicker to just cut the old shock mounts off the old plates and weld them to the new plates. Easy enough.
Picked up a couple new wheels from a local supplier. Posted an ad on the local jeep club's forum looking for a set of used tires. A guy actually gave these to me. They are 33"x10" instead of 33"x12", but they were free and in great shape, so they got mounted and will ride for a while.
The old wiring was shot, so I ran all new wires and connected up some cheap Harbor Freight tail lights. May still replace them with something a little better in the future.
The frame is all but done, so a quick test run through the neighborhood was warranted. Seems to tow pretty well.
Time for the hard work......Fixing the Tub. But, it's work I will actually enjoy. I enjoy fabricating, body work and painting, but I've never really enjoyed mechanic type work. I just don't get much pleasure un-bolting and re-bolting stuff.
The tub came back from the sandblaster with a coat of flat powder coat on it to keep it from rusting while it sits.
The tub had 10 recessed tie-downs welded to the sides. I was worried about rust underneath, so I cut them off prior to going to the blaster. Sure enough, there was some pretty deep rust. I liked the idea of recessed tie-downs in the bed sides, but they were just plain ugly. Sucks that there are 10 4" holes in the tub, but they had to go.
All painted up.
