kmroxo
no I've got a much bigger Lithium setup thats all hardwired.. none of what I did would be applicable to you.. but you can get a crimper that will do andersons fine at harbor freight and make your own cables easy enough.. MC4 are not really made for repeated connect/disconnects.. they are connect once and probably never need a disconnect again kinda connector and have poor wear characteristics, unlike Andersons.. and having adapters just adds points of failure and can be lost easy, leave the dongles to Apple products.
I used marine gauge tinned wiring, ran the gauge through a drop calculator for my longest length and picked it based upon acceptable losses (went with 12awg, for 5A @ 60V), my last setup I used normal Red/Black ZIP wire and I had a few segments get damaged pretty badly from the weather over time... like I cut em in half and could see cancer in the middle of a 15ft cable.
Thank you for the info. Do you have a preferred Anderson connector? I found the marine grade cable you mentioned.
