Mountain Goat One
2017 Toyota Tacoma TRD Offroad 4X4 V6 DCLB with AT Overland Atlas Camper Shell. Low miles Tacoma (under 38k miles). Truck is in excellent condition and is clean title with no accidents. Kept in garage or covered for most of its life and waxed twice a year. Clean inside and out. Has crawl control, locking differential, etc. Registered through May 2022. Many upgrades, including the following:
DM me for additional pics or info. The rig is currently located in Las Vegas, NV near Red Rock Casino.
Key words (ignore): AT Summit, AT Habitat, Go Fast Camper, GFC, Drifter, Popup camper, Four Wheel Camper, FWC, Hawk, Light weight camper, Offroad camper, Off-Road Camper, Alu-Cab
- Full skid plates from RCI (Aluminum option for lighter weight)
- Rock sliders. Can support vehicle lifting with Hi-Lift jack on sliders
- Custom floor mats (front and back) and custom sun screen that attaches to side of window
- Front facing camera that allows you to see in front of you as well as behind you with a touch of a button (no need to be in reverse)
- VF ECU mapping by Ovtune. Software remaps trucks computer to optimize the performance
- Tailgate pop-a-lock that locks and unlocks tailgate with remote door lock button
- Redline hood struts to open hood and hold open without using the “stick”
- Bedrug liner in truck bed (6 foot bed)
- Custom light bar just below front grill
- Upgraded Bilstein shocks on front with Fox shocks on rear
- Deaver Medium Duty springs on rear
- Bridgestone KO2 tires with good tread left
- Auxiliary battery (Odyssey) added in engine compartment to power camper power needs
- Driver “Seat Jackers” that raise the seat to provide a taller seat for more comfortable long drives
- Ruggedly designed for 4×4 travel
- Easy 30 second deployment and stowage
- Sleeps 2 standard
- Built in two piece mattress 48” x 80” x 2”
- Insulated sleeping platform and shell walls with carpet covering
- Bedding can remain in place when closed
- All aluminum & composite construction. Roof can be walked on (600 lbs max)
- Locking lift gate
- Built in wiring raceways with double USB port and 12 volt automotive socket
- Interior LED lights (amber colored) and lift gate LED light
- All season tent with no-see-um mesh windows, clear vinyl and privacy panels
- Standard color: Clear coated aluminum
- Base weight: 360 lbs
- Roof weight capacity for accessory loading (i.e bike, kayaks etc.): 100 lbs
- Sleeping platform capacity: 500 lbs
- Painted white to match truck
- 160 watt flexible solar panel mounted to roof (weighs only about 6-lbs) with solar charge controller
- Added side hatch on Drivers side so you can reach items in back of truck without crawling in
- Window (Euro style double pane acrylic) on passenger side with screen and blind
- 270 degree Rhino-Rack awning mounted on passenger side with largest shade coverage in its class
- Maxi-Vent fan on roof that quickly pulls out heat from truck or you can reverse fan and pull air from outside
- Shower / changing room pull-out system added to cab overhang on drivers side
- Roof rack rails (no cross bars as I never used the roof rack)
