TeamSkala
2021 Turtleback Expedition T3 trailer (Picked up Jan 4, 2022), Price $37,000
Our beautiful Turtleback Expedition T3 is up for sale. It has been an absolute joy but we are taking the leap into other overlanding adventures and it’s unfortunately time to part ways. Most of the 5,000 miles on the trailer are from traveling from Phoenix to NY when we picked it up from TB in Jan 2022. The rest are local miles with 12 total trips around NY. Tracks behind our Jeep JLU beautifully and you don’t even notice it behind a ½ ton truck. All the details are listed below (including the huge 23Zero walkabout 87 with the matching annex - it is the most comfortable camping bed we’ve ever slept on.)
If you are looking for a near mint, temperature controlled garage kept Turtleback Expedition T3, fully loaded with literally every option TB offers, 35” tires, title in hand, then you found it. Paid 52k, asking 37k. Photos at Turtleback Expedition T3+, For Sale
The details:
The details:
- Extras (Add-ons)
- 23Zero Walkabout 87 walkabout 87 tent
- 23Zero Walkabout 87 tall annex
- 23Zero Peregrine shower peregrine shower enclosure
- Darche eclipse 270 awning w/ awning mounting kit
- Snomaster ex67d dual zone fridge freezer
- Body
- Upgrade: Turtleback signature suspension; Turtleback exclusive with Icon Vehicle Dynamics designed and tested remote reservoir shocks, custom progressive springs
- Upgrade: Custom shower mounting bracket
- Upgrade: KC Rock light kit c-series rgb multi-color multi-use led 6-light
- 2020 turtleback trash bag - heavy duty material construction to match durability and build of the trailer. Branded with turtle logo
- Option: Expedition molle panels mounted in side doors
- Expedition premium topo graphics package, Gray, Black and Orange accents
- Expedition side box treadplate caps
- 6 inch pole storage tube
- Chassis: welded 2 x 3 galvanized tube steel chassis with 11 gauge aluminum floor system
- receiver hitches front and rear 2 inch receiver hitches
- Corner steadies dual / ark drop down corner trailer stabilizer jacks
- Roof rack
- Upgrade: Upgraded roof rack; 4 rail cargo/rtt powder coated steel rack with storage area for 30"wide camp tables, chairs, etc
- Wheels
- Upgrade: Custom tires BF goodrich 35x12.50r17 tire, all-terrain t/a ko2 (x3 - trailer and spare)
- Tailgate spare with spare mount; swing out tailgate with flip-down table, spare tire mount, and rotopax mount. mounted on idler hub assembly for axle spare.
- Trailer towing
- Upgrade: Max coupler and drop; max coupler 6k and drop hitch to suit tow vehicle
- Upgrade: Rigid reverse light kit
- 7-pin trailer connection
- Includes charge line, brake controller line, running lights, signal lights, and reverse lights
- Nose jack 2,000 lb swing away tongue jack
- Safety systems trailer break-away brake activation switch, led yellow and red side marker lights. Led brake lights, signal lights, and running lights. Integrated reverse lights. Adjustable rear stabilizer (required for disconnected hitch use). dual towing safety chains.
- Kitchen
- Upgrade: Expedition full composite kitchen, upgrades kitchen to marine grade hdpe material. waterproof and uv stable. will last a lifetime.
- Upgrade: Guzzle h2o stealth system
- Upgrade: Turtleback custom fridge slide
- Expedition slide-out kitchen
- Includes partner steel stainless stove with dual 10,000 btu 18" burners, lid, and adjustable wind guards, dual pressure propane system, dometic deep well stainless steel sink and faucet with tempered glass lid prep surface
- Dual stainless steel fold down prep tables; 18" x 36" stainless steel prep table mounted on tailgate swing out and 16" x 25" stainless steel prep table mounted on kitchen door
- Water System
- Water tank 42 gallon, food grade, bpa free, water tank with external, lockable fill door (vented)
- Water pump 12v on demand water pump 3 gpm, 55 psi, self priming
- Water heater Dometic 6 gallon direct spark ignition water heater
- Exterior use shower with dedicated valve control
- Electrical System
- Upgrade: Dual lithium package
- Dual battery electrical system, gxl 125c automotive wiring, blue sea marine-grade components, dual group 31 agm 102 amp, hr batteries for combined 204 amp-hours, battery boxes, blue sea 6 circuit fuse block, blue sea dual battery disconnect switch, 6 amp hd battery charger
- Upgrade: 2000 watt pure sine wave inverter with blue sea 150 amp breaker
- Upgrade: (soc) state of charge monitor, replaces standard voltmeter to soc monitor for enhanced battery information
- Upgrade: additional charge ports (drv rear kitchen, passenger rear kitchen, main storage compartment)
- Zamp 90watt portable panel produces 90watt at 5amps, weather resistant, 5 stage, 10amp charge controller, alligator clamp adapter included. And 25’ extension
- On-board systems control panel
- Interior sidebox mounted control panel with blue sea 8 circuit breaker panel, battery power disconnect, 2.1a usb charge port, 12v socket, oled voltmeter, and water heater switch
- Led lighting system; 4 exterior flood lights, 4 storage box lights, 1 main storage area light, 1n ose box light, 1 utility area light, 1 control panel light, 3 undercarriage lights
- Propane
- Primary propane tank; 11 lb pancake type tank for primary on-board systems (driver's side)
- Accessory 5 lb propane tank and mounting bracket (passenger side)
