For the interior we offer 30mm/ 1” panels. They match the camper shell and very easy to cut and bond.What thickness of of the honeycomb panels are available?
Will have more and better pictures of that f350 in a couple weeks when it’s done. Customer dropped of a used truck with regular bed. Our partner ITB in Surrey BC did do a subframe and assembly.What a great build you are doing . Can you tell me a bit more about the Tuesday F 350 regular cab ? Was it ordered as a cab and frame or pickup ? And is the camper box directly mounted to the frame with no flat deck needed ? Thanks
Why do you think we have a 3rd seat in the van ? baby has been around us for 4 years already ?Those are non baby making beds
Installed the 7 litre diesel tank for the planar furnace. Used fiberglass tubing and adhesive as mounting points. now I can connect the fuel line and do a test run.
not sure I understand your question... why would there be condensation in the electrical compartment?
no specific reason for the two different styles of hatches.. we thought it would be nice to have it as small table/workbench if needed. Also to show case the two different options.
Are you using the arctic tern hatches? Is your trailer insulated And heated?At the left end of the lower mounting tube for the tank there looks to be rivet in the corner molding.
I've stopped leaving my saws/axes in the lower compartment of our trailer due to condensation.
Also around 15F ice forms on the inside of the hatches. When the temp rises I open the hatches to dry out the compartment.
Trailer is heated and insulated but the tools rust the most when the heat is off and the trailer isn't being used.
Hatches are not AT.
Didn't get an answer to the corner molding. Are those rivets?Not really any comparison to our set up but at first glance a valid concern with your background.
Cheers
Was trying to having a weekend... Answered questions on the fly. Sorry for the delay.Didn't get an answer to the corner molding. Are those rivets?
