FOUND Vans For Sale!
shenrie
^^^ hates cars
not mine, posting for a friend...
1960 Olson Grumman Kurbside (6 window step van, aluminum body, Ford P350 chassis)
Ford 1-ton chassis, 138" wheelbase
Ford 223 I-6 Engine
Borg-Warner T-98 4 speed transmission
Rockwell Standard 9" rear end with 5.14 ratio (model B140NX1)
Parts Installed/Replaced
Tires & Tubes (Power King 7.5x16)
Brake wheel cylinders (front & rear)
Brake lines (front)
Brake shoes (front & rear)
Brake drums (turned and re-finished)
Kingpins (new bearings, seals, bushings)
Axle seals (front and rear)
Fluids Replaced (rear end, transmission, engine oil, coolant, brake fluid, hydraulic clutch fluid)
Clutch master cylinder and slave cylinder
Brake master cylinder
Wheel/Axle Bearings (front & rear)
Fuel Tank (replaced with new16 gallon Tanks Inc tank and fuel pickup, new lines and filter)
Fuel Pump
Starter Motor (rebuilt with new brushes)
Spark Plugs
Oil filter
Oil pan gasket
Valve cover gasket
Pushrod cover gasket
Muffler replaced
Carburetor kit installed (Holley single barrel, new float, float valve, gaskets)
Choke cable (new)
Radiator replaced (aluminum high capacity)
Coolant lines replaced
Electric Fan kit for high capacity radiator
Timing chain with gears
Water pump assembly
High beam switch replaced
Turn Signal relay
Instrument bulbs replaced
Marker lights replaced
Tail lights replaced
License plate light replaced
100 Amp alternator installed
Battery replaced (including new cables)
Side windows replaced (new window track, window seals installed)
The van is registered in Idaho and has a clean title. Drivable and ready to be converted to something amazing. Top speed is around 55 mph with the current drivetrain and gear ratio.
few more pix and some short vids of rig here:
https://photos.google.com/share/AF1...?key=b1FXX1Fta3JLLVJBcGFOY3cyMGtxMkMwM1VWUm93
Pangle
Wanderer
I was high bidder up until a few min ago.... Prices are going crazy these days. If I wasnt on the East coast I would prob go higher.
Bikersmurf
Ford 223 I-6 Engine
Brake lines (front)
Fuel Pump
Spark Plugs
Oil filter
Oil pan gasket
Valve cover gasket
Muffler replaced
Choke cable (new)
Water pump assembly
Turn Signal relay
I recently saw one of these in person... super cool ride. It had a 383 SBC stroker that was built. It was a bit of a Rat rod that didn’t look like much, but from the sound, I’m sure it’ll go like a bat outa hell.
another_mike
I don't know of a nice way to say this but I'd like to get the word out. If your ad has one of your kids in the picture, usually doing something unusual or stupid, then you're probably not the kind of person I'm going to buy a vehicle from. Am I alone?
Yes.
ilciclista
