Frame design w/ removable hitch.
Sb_Moto
I want to only have 12" of the 2.5x2.5 exposed from the 3x3 for strength reasons so I doubt I have much adjustment as far as tongue weight, but it will be nice to be able to pull 3" out and pin it to help with leverage when moving it around the garage.
1store
Banned
looking forward to your build If you back up like me. it's nice to be able to pull some out. So the trailer won,t cut so fast when backing up
Sb_Moto
Good point. I will probably go ahead and make it a 5' pull out with 3 holes in the pull out for leverage in the garage, and backing up. Thanks for all of your help!
I tried to find your build thread, but it doesn't look like you have one. I really like your trailer though!
NatersXJ6
Hmmm... I keep reading this and wondering if I'm missing something...
When you talk about using 2 receiver pins, I assume you mean one behind the other? I'm fairly certain that the second pin doesn't do anything.
the pins have to be a little loose in order to go in and out. just grab any truck receiver ball mount and wiggle it. it would be virtually impossible to machine a tube to tolerances that would have both pins in contact with the front of the hole at the exact right point to share the load. It seems like you would be better off to buy a commercial receiver tube for the female half of the tongue and receiver bar for the male half. Drill whatever spacing you think you want for adjustability in the male half, and use the factory punched holes in the tube half... Weld and triangulate that to the frame and you're good to go.
Cheaper, simpler, and less frustrating to build?
John E Davies
I joined this thread late, but I just thought I should toss in a few pics.
I use a honking big bolt and self locking nut in the back hole so I can cinch it down hard and eliminate ALL vertical movement. If there were only one pin the bar would move around, a lot. Lots of clunky noises..... This way it does not rust from chafing. Much. The front pin is a lock for security.
The Treg coupler is raised for clearance and the trailer rides level with my lifted 80 in front. The ball coupler is dropped to match a standard 18 inch ball height of lesser vehicles ;)
Each tongue is about 4ft long, the ball version is built with thinner wall than the offroad version. I like to be able to remove the tongue and store it with the unused one in the bed, off season. It gives a couple of extra feet of room in my garage.
Obviously you have to have an extra long cable and secure the excess when the bar is slid in. I have 30 inches of adjustability with both bars, it can be handy for long loads like lumber. I usually keep the Treg all the way in for maneuverability. In the second pic the bar is partly extended so the rear swing door of the RAV4 trucklet will clear the trailer spare tire.
http://www.spokanister.net/vehicles_trailer.htm
Good luck.
John Davies
Spokane WA USA
97kurt
Here is mine, wish I had a better pic handy.
Two pins, mainly as a fail safe but the front pin is locking one. Also (hard to see) I have a 1/2" threaded insert welded to the top of the receiver in between the two pins. I just apply a little tension to the bolt and there is no wobble or play in the receiver.
Sb_Moto
Awesome ideas guys!
I really like the idea of the top bolt to apply pressure to reduce the wobble!
I have never heard of a treg coupler, but I will be looking into them. I like the way that you have your setup!
1store
Banned
There many ways to go .What one person calls off road is someone else tea party .A little slop is not a big deal . As you build this trailer think what you may use it for in ten years . This is pulled out will try to get picture of the boat rack .It uses the 5/8 pin to hold the rack on.
