Free Spirit Recreation Odyssey Silver Top Tent 49" BNIB
will0861
Up for sale is a brand new 49" FSR Odyssey RTT and ladder. This tent is still in the box. This is the silver top, with grey fabric. The images are stock photos for illustration only. I will accommodate as best as I can if you would like confirmation that I have the tent. I understand buying sight unseen can be frustrating, so I can provide additional images, if needed. I do want to avoid opening the box before a sale is made just so that I can ship the tent if need be. I would prefer a local pick up, since this tent will likely have to ship via freight. The tent is located in Corona, CA. I will consider delivery if within a reasonable distance.
Asking $2995.
INTEGRATED LIGHTING
A thin light strip is nestled overhead your sleeping quarters to quickly illuminate your entire tent when needed. It powers via USB type A, and Velcro's away for easy replacement.
INSULATED TENT BODY
The sonic-welded Tri-Layer fabric keeps you warmer in the winter and cooler in the summer, while wicking moisture away from the fabric.
Interior Opened Dimensions
48"W x 83"L x 43"H
Exterior Closed Dimensions
52"W x 87"L x 7.1"H
Weight
134 lbs
Sleeping Capacity
1-2 people
Weight Capacity
750 lbs.
ShellAluminum Honeycomb Plate
Tri-Layer Body3 Layers of 150D Poly-Oxford with 90g/M2 Poly-fil
Rainfly210D Poly-Oxford with Silver Coating and 3,000mm Polyurethane coating
Mattress1 1/4" High Density Foam
Flooring
1 1/2" EPE
FramePatented Aluminum Gas Strut-assisted
  • 0S5A4226_L_1800x1800_17b17c6a-bef4-422b-bd10-632b1688a3a9_1024x1024-2827329075.jpeg
WonaWarrior
