Zam15
Ok,
I recently installed a 60 watt solar panel and would appreciate any input.
Solar Spec:
60 Watts, 4 Amps, 15 Volts Out Per Hour
Average 7 Hours of Daylight - 28 Amps Per Day
Fridge Spec: (ARB Ref)
.7 to 2.3 Amps Per Hour
16.8 to 55.2 Amps Required Per Day
I am looking to have my solar setup negate the power used by a fridge. Basically operating the fridge 24/7 without the need for an outside power source. Max power draw from the firdge for this to work is 1.1Amp Hr?
If power use falls into the .7Amp/Hr range I will have more than enough power.
If it falls under the 2.3 range the battery will start to deplete. (5 Days on a 130Amp Hour Battery)
Sunny Day: Fridge has to work harder but more solar energy is available.
Cloudy Day: Fridge does not have to work as hard and normally less solar is available.
So my two questions are:
What are the best fridges on the market in terms of power use?
If you have a fridge what kind of average draw are you getting?
Thanks!
Solar Spec:
Thanks!
