FS:1994 NAS Defender 90 ST #1194 in Phoenix
jedelmann
1994 Land Rover Defender 90
SALDV2289RA941805
$65,000
Alpine White
5-speed, A/C
98,000 miles
I’m selling the D90 to offset some of the costs of the 110 I recently purchased. It is a really super clean, rust-free D90. It has been meticulously maintained by Rov-N-Techs in Scottsdale and is mechanically sound. Over $20,000 worth of work/adds have been done to the vehicle since I’ve purchased it. I have all receipts for past 3+ years.
While it’s registered in Illinois, it’s never seen a Chicago Winter and has always been garaged in my Phoenix home since I purchased it 3+ years ago. It has been a Southwestern vehicle (Arizona, Utah, Southern California).
Features:
• 5-Speed Manual
• Original Fiberglass Hardtop
• Warn Winch
• Ice Cold Air Conditioning
• 2 Hella Lights
• ARB Front Bumper
• AM/FM/CD Radio with IPod Adapter
• Lockable Tuffy Box
• Forward-facing Foldable Rear Seat
Work Completed:
• Muffler Replaced
• Main Seal Replaced
• Transfer Case Leak Repaired
• Front Pinion Seal Replaced
• Throttle Position Sensor Repaired
• Ignition Module Repaired
• Exhaust Manifold Gaskets Replaced
• Replaced Idler & A/C Pulley
• Alternator Replaced
• Fuel Pump Replaced
• Brake Job/Wheel Bearings Repacked
• Added Heat Shields
• Power Steering Flush
• Dynamat added to doors, floor, boxes and hood
• Starter Assembly Replacement
• New Battery
• Replace Turn Assembly
• Doors Re-Keyed
• Speedo Sensor Replaced
• Oil Cooler Hoses
• New Radiator/Thermostat
• 90K Service/All Fluids Changed
• Replaced Belts/Hoses
Apologies:
• Undercarriage could benefit from a scrub brush and elbow grease.
• 2 small chips in paint on right side
• 4 small chips in paint on left side
• Minor aluminum corrosion on driver/passengers door panels
• 1” surface crack on left rear corner of hardtop
• Shallow dimple on right wing
• Rear Cargo Mat is torn (have replacement)
Also Included:
• Brand New Tires (5) BFG A/T TA KO2
• Used BesTop bikini top (never used)
• Rock Sliders
• New Cobra CB/Weather Band and Firestick Antenna
• New 2 Lockable Tuffy Boxes mounted on rear wheel wells
• New 3rd Light Bar
• Half-Roof Rack
• 2 ARB Fuel Canister Mounts
• 4 Fuel Canisters
• New RN Front Seat Cushions
• New RN Rear Mat (still in box)
• Quick Release Fire Extinguisher Mount/Fire Extinguisher
• LED Headlights
• New 7-Pin Tow Harness
• Hand-made, 3-piece removable wooden platform that can be used to sleep comfortably in the Defender.
If interested, you can contact Joe at Rov-N-Techs to discuss the condition of the vehicle. I commute between Chicago and Phoenix so please have a little patience if you want to have someone inspect the D90 in person.
John Edelmann
847-414-4999
john@cloverleafinnovation.com
vertical.dan
