FS M101A2 Trailer $2400 Overland ready, new axle, tent rack, bed cover, 2" hitch,
Last1Left
Well my type of travel will be changing over the next few years as such I will not be using this trailer. To start the tents that are pictured are sold and not included, I have included the pictures so you can see how two tents had been mounted. This trailer started life as a M101A2 with a pintle and surge brakes. Trailer was sandblasted and repainted with Raptor liner, Just the top was done not the bottom, (this was done by previous owner). I wanted to replace the axle and move to a Toyota tacoma wheel pattern 6 x5.5, I ordered a Dexter 7k axle with electric brakes, original shock mounts were removed from the old axle and reworded to the new one. I also utilized well spacers to adapt From lug centric to Hub centric on the TRD offload Tacoma wheels. Tires are BFG AT 265/75/16 8k miles. Next up was taking off the old pintle and surge brake assembly, it was replaced with a longer extension and a 2" fabricated hitch. You can use whatever type of assembly you would like, (like and Roll, etc) comes with a pintle with a Pintle Hitch and receiver. The drop down wheel was replaced with an ARK dual wheel trailer Jack $500, same as used on the high end trailers. Also installed are rear RV levelers, increase stability when moving in the tents. A custom two level rack was built. The two levels are to allow the front tent to be low enough for a vehicle mounted bat wing style awning to be deployed without unhitching the trailer. Complete new trailer wiring installed,LED lights, marker lights, trailer pig tail 7 pin. Also has a auxiliary battery and wiring for it to charge from the tow vehicle. Front alum tool box houses electrical and battery. ARB drawer and Tonneau also included. No water system, although there is a fill port on one side.
Please feel free to ask any questions. I have towed this from Ohio to South Carolina to Maine and back to Ohio, gussying total milage since rebuild/refresh is 6-8k.
Located in Medina, Ohio. I am willing to drive and meet, within reason 200 miles.
Price is $3250
Last1Left
Last1Left
WonaWarrior
