Full Size Dodge Thread
konfuzed
There are some awesome trucks on here! Here is my peasant mobile. Its a 2014 ram 1500 lonestar 4x4. I've got a 2.5 level sitting on bronze 20x10s -24 offset, wrapped in 35x12.5x20. I just recently found a camper shell used, had it painted to match. I have mounted fishing rods on the driver's side as well as ran power wires and 12v outlets and battery dial. Locking bed boxes on both sides. On the passenger side I've mounted my ? and shovel with quick fist. As well as a switch for all of the bed lights. I have up graded the entire front end. Cowl induction hood, which let's my hemi breathe through a Mopar cold air intake. The bumper is from body armor, which i also order all of the led lights up front. I painted the .50 cal short antenna, emblems and grill bronze to match my wheels. I wrapped my door handles in black. I've done little things throughout the truck. I love the truck, its perfect for my family's needs, and powerful enough to keep my attention. It is my daily driver so I'm not rock crawling with it but I have carried it down some very questionable jeep trails. I'm ready to hit the trails
Sent from my SM-G988U using Tapatalk
Spade33
Here is my 2000 ram 2500 24v 5.9 diesel automatic, Been lurking here a while reading as much as i can. Bought a used camper shell and cleaned it up, bought some cheap white roll on bed liner and sealed it all up. Currently have a 50w renogy solar panel run to a goal Zero 150 Ive had for years. Got a yeti in the back seat at all times i keep tied down and snacks in. Working on slowly getting a bed and drawer system built to put into the camper that I can also easily take out. Hoping to do a bunch of road/overland trips here in the future as things die down around the country. Anyways, I was goign to make a thread to introduce myself BUT I saw this and figured I’d throw it in here. 0F1830BB-59EB-40E2-9542-DA06943F6FE6.jpeg
Regcabguy
Oil eater.
Looks great. You could use a rubber bedmat and tailgate one.
Gummee
wannabe traveler
My new-to-me 04 2500 CCSB should be coming on Tues.
1 owner, gas engine, 5sp manual, 120k miles. Little rust over the fenders, but otherwise? darn good shape.
Likely to look like the white truck posted a bit ago once I get it where I want it.
M
J.R.M
New to the site, heres my jalopy. 1994 Cummins, started out as a 2wd I bought from an ol' timer with 72k on it. Bought a burnt out 1994 4x4 with a V10 for pennies and swapped cab and engine to the 4x4 chassis. Drove it for a year and started having trans issues. Got a new job that requires a lot of driving so I parked the dodge and bought a civic as a work/daily. Anyways, my gaze turns back to the dodge and Ill probably drop the trans, hit it with a hammer, and hopefully fix my problems. More to come on the dodge as well! Shes an ugly wench but shes mine and I have a lot of blood, sweat, and beers into her! Hoping
to get in some fun trips this summer.
It’s been a busy week for me and my old girl. She had started making a rattle noise that I had some trouble diagnosing where exactly it was coming from because it was very intermittent, found out my factory cat had decided it was done and broke apart and started to rattle around like a bunch of marbles
So I decided we don’t need no stinking cat!
Found out the the y pipe on the Durango and Dakota with the 5.2/5.9 uses the same y pipe it just does not have the cat. So I ordered one from autopartswarehouse and installed the new y pipe and made my own extension out of some extra pipe I had laying around.
She sounds so much better now! Nice and throaty on accel and the magnaflow muffler keeps it quiet when cruising. After that took her out to play at the local river with a couple buddies.
On our way back out she decided to stall out and die on me because the factory crank sensor broke off the mounting bracket. New sensor and a few days later and she is all ready to go play some more!
jonathon
Must be a 94 or 95? If you decide you don’t like the stink of raw exhaust, throw an eBay cat on it. Cheap and it works. Those stock pellet cats suck.
guapstyle
